Advanced Member polynut Posted June 27, 2019 Advanced Member Report Share Posted June 27, 2019 (edited) Hi guy's me again with alpha stamp size issue, you can clearly see in the gif i made that the alpha once stamped on the surface is 20% bigger then the brush size. I tried in surface mode and same size problem.Could this be related to my stamp being 2048 X 2048 in size? What is causing this and also so far i have all sort of random weirdness working with alpha to a point that i wonder if i will be able to use it in production? Edited June 27, 2019 by polynut info missing Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 28, 2019 Reputable Contributor Report Share Posted June 28, 2019 Share the alpha if possible to see if it happens to others. Quote Link to comment Share on other sites More sharing options...
Advanced Member polynut Posted June 28, 2019 Author Advanced Member Report Share Posted June 28, 2019 16 hours ago, digman said: Share the alpha if possible to see if it happens to others. I send you the alpha via pm since i cannot share asset on public space thank for helping. Quote Link to comment Share on other sites More sharing options...
Advanced Member polynut Posted June 28, 2019 Author Advanced Member Report Share Posted June 28, 2019 Did a few more test and believe it or not it took about 5 3d coat restart before it work correctly and 2 time out of 3 it start all over again to a point that i will forget 3d coat and use blender instead for alpha and stamp stuff since i don't get weird thing happening and i need stability. Quote Link to comment Share on other sites More sharing options...
