[Solved] vox layer
castaneda
Im having problems with the vox layer tool. The thickness parameter does not work. Ive uploaded a pic to show as an example. As seen it comes out way to thick and not equal to the input. Also, although this hasn't happened in a while , the result will increase the layer resolution to 25x or 50x. Hope someone can help with this. The vox extrusion tool works just fine but I want a separate object such as in this case a piece of clothing.  Thanks for any help.
  • Carlosan changed the title to [Solved] vox layer
