Advanced Member castaneda Posted July 5, 2019 Advanced Member Report Share Posted July 5, 2019 Im having problems with the vox layer tool. The thickness parameter does not work. Ive uploaded a pic to show as an example. As seen it comes out way to thick and not equal to the input. Also, although this hasn't happened in a while , the result will increase the layer resolution to 25x or 50x. Hope someone can help with this. The vox extrusion tool works just fine but I want a separate object such as in this case a piece of clothing. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 5, 2019 Report Share Posted July 5, 2019 Look as the model is very tiny maybe... Common is to use 3/4 size of default grid. Quote Link to comment Share on other sites More sharing options...
Advanced Member castaneda Posted July 6, 2019 Author Advanced Member Report Share Posted July 6, 2019 Thanks Carlosan. That did the trick. My model was very small against the grid. Thanks again. 1 Quote Link to comment Share on other sites More sharing options...
