Dennis Nikolaidis
batch processing through command line possible ?
I have a simple task that involves importing pointclouds with specific settings and exporting the models out.
It can be quite a time consuming task as the point clouds are pretty large and I really don't care about previewing the models created in 3D if that slows down the process. Is there any way I can speed this process up by a batch script that goes through all point clouds in a directory automatically?
Hi
- 3D-Coat uses AngelScript.
- Script is a text file. It is helpful to view and edit it in Notepad++ (choose "C" syntax).
- Run script via file menu "Scripts / Run Script".
related
http://signmotion.blogspot.com/
The documentation added to official site http://3dcoat.com/scripting
Hope it help.
Thanks.
I was interested for something less complicated than writing /constructing a tool from scratch.
It is cool that angelscript allows you to do that, but I wanted a higher level instruction like:
(pseudo code)
run import pointcloud file tool using variables A and B
export generated mesh as "name1"
delete layer.
I guess that would more closely resemble Mel scripting in Maya.
If I have to write an importer from scratch, then a mesher from scratch, then a file exporter from scratch, then it most probably defeats the purpose.
