Import of curves/spline!!
RonneySingh
Go to solution Solved by AbnRanger,
Hello,
In order to draw something very precise I would like to not use curves directly from 3Dcoat but import them from another software. (as DesignSpark Mechanical 4.0)
Does is possible ?
What I want:
I created a vase and I want add two ropes perfectly horizontal.
But My hand is shaking and the result is bad.
Desastrous result
  • 3 years later...
  • Solution
Carlosan
AbnRanger was awarded the badge 'Great Content' and 1 points.
5 hours ago, Carlosan said:
Hi
You can import curves from Curves menu as .eps format
I tried this successfully on a project where the client had some SVG vector art, and I brought those into Illustrator and exported as an .eps file. Another option the user can try is to go to the FILE menu > IMPORT > CURVE AS MESH
