Member zebrap Posted April 24, 2020 Member Report Share Posted April 24, 2020 On 4/22/2020 at 9:36 AM, tcwik said: move tool bug :/ Hi tcwick, I've had a similar issue not long ago. It mostly happened after an undo when the tool was still active. A clean un-installation and re-installation of 3D Coat solved the issue in my case. I'm not sure if it was related to my config files or else. Back up your presets, preferences etc. and try to start afresh. Hope that helps. 1 Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 27, 2020 Author Report Share Posted April 27, 2020 27.04.20 4.9.41 (beta, close to stable) - 3D-printing friendly mode in start thumbnail. - Catmull-Clark subdivision in retopo room. Two different commands - "Subdivide selected" and "Subdivide whole group". Enable in preferences, Beta tools. - Edit->Preferences reorganized, Beta section moved to own tab. - Optional "Factures" room - may be turned ON in Edit->Prefs->Beta - Possibility to set a special folder just for textures in the export dialog. - Smooth, SHIFT, CTRL+SHIFT smoothing options supported in Voxel mode in the surface section. - Click on Downgrade/Restore will not cache/uncache immediately to avoid unintended action. - SHIFT and CTRL+SHIFT mechanism changed in Sculpt room to prevent incorrect CTRL+SHIFT action. - Fixed "Geometry->Weld vertices". Not it does not corrupt meshes even if mesh structure is wrong. It allows to use this command as "mesh healer" if mesh becomes corrupt. - Speed-up for the "Remove strenching" lag at the end of stroke. - Fixed brushing in surface mode over transformed volumes. - Correct displacement painting (in paint room) for transformed volumes. - Previewing (and other visual) problems of Tapering tool solved. - No pen controls in Primitives/Transform/Bas-relief/Undercuts tools (was distracting and unnecessary) - Constructor tool UI problems solved (too big icons). 2 1 Link to comment Share on other sites More sharing options...
philnolan3d Posted April 27, 2020 Report Share Posted April 27, 2020 What is Factures? I see it just has 3 tools, paint, erase, fill. Link to comment Share on other sites More sharing options...
Carlosan Posted April 27, 2020 Report Share Posted April 27, 2020 On 2/6/2016 at 4:09 AM, Andrew Shpagin said: Factures are sort of big "easter egg" in 3D-Coat. Actually it is very powerful way to make super-detalized objects. For example you have landscape and want to cover it with grass, rock, sand etc textures. Of course direct painting over uv-ed mesh is bad idea there - huge textures will be required. Putting tiled texture is bad idea as well - tiling is well visible, edge between different textures is visible too. Factures is good solution for this. It is per-vertex textuing. UV coordinate assigned to vertex, textures are assigned per-vertex as well, if different vertices has different textures - they will be blended between each other and no seams will appear. But there are several problems: 1) Export. Engine/3d-package should support per-vertex color/alpha channel to use FBX exported from Coat. Usualy need to setup nodes to use exported result correctly. 2) Still unfinished a bit. No good textures, no defaul library of textures. No shaders included. I will include shaders in next build. That technology may be amazing and revolutionary, but still unfinished. But we are slowly moving it to useable state, it is not fast process. Some help may be really helpful - need license-free textures for factures. Grass, rocks, sand, etc with color, gloss and normalmaps. 2 Link to comment Share on other sites More sharing options...
philnolan3d Posted April 27, 2020 Report Share Posted April 27, 2020 Ah thanks I missed that. Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted April 27, 2020 Reputable Contributor Report Share Posted April 27, 2020 In what way is it better than splat maps ? What engines can you actually export to with this ? why not implement a way to export these factures as a splat map easily ? (just curious, never tried any of this) Link to comment Share on other sites More sharing options...
Advanced Member jene Posted April 28, 2020 Advanced Member Report Share Posted April 28, 2020 3 hours ago, Andrew Shpagin said: - Catmull-Clark subdivision in retopo room. Two different commands - "Subdivide selected" and "Subdivide whole group". Enable in preferences, Beta tools. it is good news. but I don't find increase/decrease Slider. Is that function irreversible? if... if increase/decrease "reversible" catmull-clark , I think more wonderful. 3 Link to comment Share on other sites More sharing options...
Carlosan Posted April 28, 2020 Report Share Posted April 28, 2020 @Silas Merlin - ArtOfSoulburnMap is only as detailed as the amount of vertices in your mesh. So you need lots of geometry to get detail - robinbVertex colours are tremendously useful in game engines. We use them for all sorts of data. What specifically they’re used for will depend on the game engine and the shader on the object. At the most basic level, they can be used to tint objects so you don’t need multiple textures for different colours. This is also why they were originally used to hold lighting values. Baked lighting per vertex is very very cheap, albeit low res. They can be used to blend textures for terrains. Especially useful here as textures will need to tile over large areas, but not look tiley. You can use a huge mask texture, but vertex colours are much cheaper and you don’t need to set up a second Uv channel with all unique uvs. They can even hold values for things like how much to move if an object is dynamic cloth, or be affected by wind, like trees swaying. If you think of them as four values per vertex (RGB and alpha), there’s all sorts of things you can use them for. source... 1 Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted April 28, 2020 Reputable Contributor Report Share Posted April 28, 2020 12 hours ago, jene said: it is good news. but I don't find increase/decrease Slider. Is that function irreversible? if... if increase/decrease "reversible" catmull-clark , I think more wonderful. In the retopo room, subdivision is not in levels that you can step up and down in, or with a modifier that you can switch on and off. At least not at this point. It would be nice to have that kind of option. 2 Link to comment Share on other sites More sharing options...
Member tcwik Posted April 28, 2020 Member Report Share Posted April 28, 2020 [4.39.41 Gl/Dx] ..Pointing [by shortcut in Voxel room] still not work correctly plus 'split with' [Voxel Boolean action] have the same bug with selection, like 'subtract from' [Voxel Boolean action] couple numbers earlier ;] Link to comment Share on other sites More sharing options...
Advanced Member insignet Posted April 28, 2020 Advanced Member Report Share Posted April 28, 2020 Fractures in the render room. Tiles visible and artifacts ( voxel mode ) GL version... anyone else confirm? 1 Link to comment Share on other sites More sharing options...
Advanced Member pickers Posted April 29, 2020 Advanced Member Report Share Posted April 29, 2020 Z-up option in preference went missing? Link to comment Share on other sites More sharing options...
Member Werner_Z Posted April 29, 2020 Member Report Share Posted April 29, 2020 EXR export broken in 4.9.41 Here I exported TIFF at 16bit, as well as EXR Looks like the EXR has the wrong gamma. Reds looks orange. Link to comment Share on other sites More sharing options...
Advanced Member jene Posted April 30, 2020 Advanced Member Report Share Posted April 30, 2020 my friend says, 3D mouse can not use in v4.9 . he says, "I was able to use 3D mouse until V4.8.40. but I can not use it since V4.9". his PC is macOS catalina. he uses 3D connextion mouse. does anyone has same issue? Link to comment Share on other sites More sharing options...
Advanced Member jene Posted April 30, 2020 Advanced Member Report Share Posted April 30, 2020 hello, carlosan, Abnranger. reply thank you. I will wait a future request. thank you. Link to comment Share on other sites More sharing options...
Advanced Member Vexod14 Posted May 1, 2020 Advanced Member Report Share Posted May 1, 2020 This "Factures" tool seems indeed really powerful (or at least extremely interesting especially for accurate terrain/environment mesh vtx painting). Cool news ! Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted May 1, 2020 Reputable Contributor Report Share Posted May 1, 2020 On 4/30/2020 at 4:14 AM, jene said: my friend says, 3D mouse can not use in v4.9 . he says, "I was able to use 3D mouse until V4.8.40. but I can not use it since V4.9". his PC is macOS catalina. he uses 3D connextion mouse. does anyone has same issue? I'm using a Spacemouse everyday in the newest 4.9 builds. Windows 10 1 Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted May 3, 2020 Reputable Contributor Report Share Posted May 3, 2020 I am still on 4.9.39, so, some of these may be fixed now ? Anyway, here are some bugs/problems I noticed lately : --- Drag and drop a jpg image with the .jpeg extension to the stencil panel : no stencil gets created and you get a tiny popup that says just "ca". Rename the file to the .jpg extension and now you can drag and drop to create a stencil. --- Paint room. Paint an area with freeze tool. In Freeze menu, click "Show/hide freeze". Press 2 or View menu > Flat shade : the frozen pixels become visible in black. (expected behavior being that they remain not visible) Press 5 for smooth shade : the frozen pixels are still black, but you can now use "show/hide freeze" once more. --- Create a mesh with two surface materials with connected islands texture size 2048 In paint room, Freeze menu > freeze surface material (choose one) Freeze menu > smooth freezing >>> 3dc starts spinning, computer heats up, have to end process in task manager. In this situation the freezing occurs for other items in that menu too, like expand frozen area and such. --- When you do Objectify Hidden, the new layer_hidden becomes the active layer. My expectation is that the hidden geometry has beeen MOVED to this new layer. HOWEVER, it has not been moved, it has been DUPLICATED. The hidden voxels are still on the original layer. BECASUSE the new layer has become active, it is easy to forget that the hidden voxels are still there, on the original layer. Later, you find yourself working on the original layer and forgot about this. If you hide new voxels, and objectify them.... it objectifies the voxels you thought were deleted, along with the new ones. Link to comment Share on other sites More sharing options...
philnolan3d Posted May 3, 2020 Report Share Posted May 3, 2020 On version .41 but I think I've seen this before. In Surface mode the Cutoff tool keeps creating inside out geometry as it cuts away the part I want. cutoff_bug.mp4 1 Link to comment Share on other sites More sharing options...
Member tcwik Posted May 5, 2020 Member Report Share Posted May 5, 2020 [4.39.41 Gl/Dx] After saving file my ghosted object is automatically un ghosted ..feature or bug? XD Link to comment Share on other sites More sharing options...
Member Antidamage Posted May 5, 2020 Member Report Share Posted May 5, 2020 Trying out .41 and it never finishes loading, 64-bit DX. Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted May 6, 2020 Advanced Member Report Share Posted May 6, 2020 Colour Pallette bug, It seems if I add a colour or delete or any action basically ,it will not update the action until I physically resize the Tab. Annoying. Its been in the last few beta I think, Ive not been painting recently. Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted May 6, 2020 Author Report Share Posted May 6, 2020 6.05.20 4.9.42 (beta, close to stable) - Z-up option restored. - Much better quality of "Expand/tie off" for patches and tubes for curves modifiers. - Factures rendering corrected. 2 Link to comment Share on other sites More sharing options...
Carlosan Posted May 6, 2020 Report Share Posted May 6, 2020 Note: To simplify importing of Quixel materials dev team implemented searching and importing not only zip-archives, but already extracted folders too. Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted May 8, 2020 Author Report Share Posted May 8, 2020 On 5/3/2020 at 2:02 PM, Silas Merlin said: I am still on 4.9.39, so, some of these may be fixed now ? Anyway, here are some bugs/problems I noticed lately : --- Drag and drop a jpg image with the .jpeg extension to the stencil panel : no stencil gets created and you get a tiny popup that says just "ca". Rename the file to the .jpg extension and now you can drag and drop to create a stencil. --- Paint room. Paint an area with freeze tool. In Freeze menu, click "Show/hide freeze". Press 2 or View menu > Flat shade : the frozen pixels become visible in black. (expected behavior being that they remain not visible) Press 5 for smooth shade : the frozen pixels are still black, but you can now use "show/hide freeze" once more. --- Create a mesh with two surface materials with connected islands texture size 2048 In paint room, Freeze menu > freeze surface material (choose one) Freeze menu > smooth freezing >>> 3dc starts spinning, computer heats up, have to end process in task manager. In this situation the freezing occurs for other items in that menu too, like expand frozen area and such. --- When you do Objectify Hidden, the new layer_hidden becomes the active layer. My expectation is that the hidden geometry has beeen MOVED to this new layer. HOWEVER, it has not been moved, it has been DUPLICATED. The hidden voxels are still on the original layer. BECASUSE the new layer has become active, it is easy to forget that the hidden voxels are still there, on the original layer. Later, you find yourself working on the original layer and forgot about this. If you hide new voxels, and objectify them.... it objectifies the voxels you thought were deleted, along with the new ones. Thanks for reporting, fixed most of..., but freeze not reproduced. Could be good to get example scene to andrewshpaging@gmail.com Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted May 8, 2020 Reputable Contributor Report Share Posted May 8, 2020 5 hours ago, Andrew Shpagin said: Thanks for reporting, fixed most of..., but freeze not reproduced. Could be good to get example scene to andrewshpaging@gmail.com Thanks. email sent. I could post the file here too for others to try to reproduce, it's a cc-by mesh from web. Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted May 8, 2020 Reputable Contributor Report Share Posted May 8, 2020 Additional small problems, still 4.9.39 : ------- Shift+LMB no longer smoothes the mesh with Move tool. ------- Retopo room : Uv tools Once a preview of a newly created island exists, moving the vertices (holding RMB) does not result in a new updated preview (you have to delete a seam and then add it again to get a new preview) Link to comment Share on other sites More sharing options...
Advanced Member Ratchet Posted May 8, 2020 Advanced Member Report Share Posted May 8, 2020 (edited) h On 4/28/2020 at 10:14 AM, Carlosan said: Vertex colours are tremendously useful in game engines. We use them for all sorts of data. What specifically they’re used for will depend on the game engine and the shader on the object. At the most basic level, they can be used to tint objects so you don’t need multiple textures for different colours. This is also why they were originally used to hold lighting values. Baked lighting per vertex is very very cheap, albeit low res. They can be used to blend textures for terrains. Especially useful here as textures will need to tile over large areas, but not look tiley. You can use a huge mask texture, but vertex colours are much cheaper and you don’t need to set up a second Uv channel with all unique uvs. They can even hold values for things like how much to move if an object is dynamic cloth, or be affected by wind, like trees swaying. If you think of them as four values per vertex (RGB and alpha), there’s all sorts of things you can use them for. So 3D coat is bringing multi material painting using vertex colors. Let's do a reverse usage on painted model below : From a model painted with a material doing erosion and scrathes, could 3D be able to extract the tiling textures and correct Vertex paitning values ? - blue metal paint tiling texture - erosion metal tiling texture - vertex colour map Similar to some Substance Designer materials, this would decrease a lot textures size as instead of 4K texture painting and baking, we could use two small tiling textures and a vertex color map for that model. Edited May 8, 2020 by Ratchet Link to comment Share on other sites More sharing options...
Carlosan Posted May 10, 2020 Report Share Posted May 10, 2020 Any Smart Material filled on the model shows cuts at the seams. Any1 ? Thx Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted May 10, 2020 Reputable Contributor Report Share Posted May 10, 2020 @Carlosan I get this : when trying to fill. some areas are not painted at all. This is right after baking with normal map on 4.9.42 : -I select layer 1 (layer 0 is selected by default after bake for some reason ?) -pick a smart material and fill tool. click on the mesh : nothing happens -switch to paint brush and paint : it paints; -swith to fill tool again, click on the mesh, I get this : -Now I save the file. -Reopen -select smart material and fill tool again, then click on the mesh. I get this : -Now, I do Texture > calculate curvature -then I fill again : No more artifacts at the seams Test file (which won't produce artifacts) : test.zip 2 Link to comment Share on other sites More sharing options...
