Advanced Member houGenie Posted August 25, 2019 Advanced Member Report Share Posted August 25, 2019 Hello 3d Coat community, I started to use 3d Coat again and I am working on a a project of mine now. May I say, that I love it! It is really cool and powerful. Sometimes I discover so problems with the brushes. The pinch brush works not really clean when used with a curve (manual strokes are better). Look at the picture at the bottom. You see the pinch is not uniform at all. Spacing is deactivated on the brush (setting to zero, does not solve the problem). Can someone help me, please? I have a feeling, that this problem does not occur only with the pinch brush but with all brushes which work inconsistently. Hope someone has an idea. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 25, 2019 Report Share Posted August 25, 2019 You are right, The pinch brush works not really clean when used with a curve. I am reporting this issue as bug. Thx for point it up. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted August 25, 2019 Author Advanced Member Report Share Posted August 25, 2019 Are there some good alternative methods to achieve the same (except the obvious manual method)? Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted August 25, 2019 Author Advanced Member Report Share Posted August 25, 2019 It seems that is not a pinch problem, but how the brushes work. Here an example of the build brush. Although no spacing is used, you clearly see the alpha (a square). And there is no possibility to make it continues, even with spacing set to 1%. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 25, 2019 Report Share Posted August 25, 2019 Try this settings please Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted August 25, 2019 Author Advanced Member Report Share Posted August 25, 2019 3 hours ago, Carlosan said: Try this settings please Yes, if you activate spacing and enter a small value, it works good enough. Unfortunately the pinch tool works not clean whichever value you enter for spacing. But nonetheless thank you! Quote Link to comment Share on other sites More sharing options...
