3D Printing Supports
Carlosan
This video demonstrates the general usage of the 3D Printing Supports feature, in 3DCoat
  • 2 years later...
Hi. Is it possible to somehow parametrically set the parameters, such as the thickness of the supports, or make the supports one or two nozzle diameters wide to make them easier to separate?
Hi
You can set parameters on Tool Options Panel
Is any control missing or do you need a new one ?
  • 9 months later...
On 10/18/2021 at 6:05 PM, Carlosan said:
Hi
For some reason, the program generates supports under a flat surface set to zero by azi z - i.e. which is on the floor with its entire surface, but supports are generated even under it.
This occurs even when the plane is below ground level.
Edited by Barrel
  • 3 weeks later...
Try using RMB > Snap to ground to set it to zero.
  • 1 month later...
