micro26 59 Report post Posted September 15, 2019 Hey, i have several zbrush alphas that i want to use in 3dc . Is there an easy way to remap the height for depth. Zbrush is black to white depth and 3dc is 50%grey zero depth for height map . I found this but though if there was an easier way to do this. THanks in advance! Share this post Link to post Share on other sites
micro26 59 Report post Posted September 16, 2019 I made some test and this is what i found about it: psd format in 3dc treats 50grey as border, png is better for alphas. you can convert alphas in ps or gim etc with just tweaking levels output raising the black to 50 percent. zbrush has a slider for that job , mid value slider that changes the range of the alphas. would be cool to have it in brush options in 3dc Also brushes that have range black zero work fine in surface draw but not in live clay brushes. Hope someone finds there usefull. 1 Share this post Link to post Share on other sites
Gary Dave 94 Report post Posted September 16, 2019 Have you seen the videos on creating brush alphas? Maybe somewhere in there you can find out how to use your Zbrush alphas in 3dc, even if it means a lot of manual tweaking: Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted September 16, 2019 I am unsure if there is a way to convert zbrush brush (zbp) file type, because it contains more data than just the image itself. However, you can get the image/alphas for the brushes and import them right into 3DC without any issues. Share this post Link to post Share on other sites
micro26 59 Report post Posted September 16, 2019 5 hours ago, Carlosan said: I am unsure if there is a way to convert zbrush brush (zbp) file type, because it contains more data than just the image itself. However, you can get the image/alphas for the brushes and import them right into 3DC without any issues. actually i dont want to load zbp to 3dc . I m simply stating that there are issues with loading image/alphas (as is ) because of mid level convertion and live clay brushes. Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted September 16, 2019 Is there no average MidValue between 0 <- > 1 to export without troubles ?Mid Value set the zero displacement value. If set to 1, then white is considered zero displacement and all sculpting will push in on the model. If set to 0, then black is considered zero displacement and all sculpting will push out of the model. Setting Mid Value between 0 and 1 allows you to sculpting in and out at the same time. Related: This issue was reported. Feel free to add a+1 0001394: black parts of brush heightmap are not displacing geometry with LC brushes 1 Share this post Link to post Share on other sites
kenmo 217 Report post Posted June 28, 2020 After downloading Digital Hunky's ZB alpha brushes from Cubebrush ---- > Using Photoshop CC 2020 I did this to convert a ZB alpha to 3DC alpha Share this post Link to post Share on other sites
kenmo 217 Report post Posted June 28, 2020 1 - Opened the ZB alpha png file in Photoshop. Share this post Link to post Share on other sites
kenmo 217 Report post Posted June 28, 2020 2 - I then used select all and copied the complete ZB alpha 3 - I created a layer mask "reveal all" and pasted into the the layer mask the image I copied Share this post Link to post Share on other sites
kenmo 217 Report post Posted June 28, 2020 04 - With the mask applied created this image. I then save the image as a PNG Share this post Link to post Share on other sites
kenmo 217 Report post Posted June 28, 2020 05 - After importing into 3DC as an alpha for use in the sculpt room. Seems to work but there maybe issues I have not encountered yet. Your results may vary from mine but of the 34 ZB alphas I've tried it on this afternoon, I've had no issues yet. Cheers...stay safe & healthy.... Kenmo Share this post Link to post Share on other sites
kenmo 217 Report post Posted June 28, 2020 Here's another ZB alpha I converted to 3DC alpha using the above process.... The only issue I noticed is when you load the brush it looks kind of jagged. However the results from the brush in the sculpt room are acceptable at least IMHO. 1 Share this post Link to post Share on other sites
