Anders68
AUTO retopo crashes 3dcoat on OSX
Hi! I use 3D coat 4.9.02 (GL64) Trial version on my iMac Pro with MacOS Mojave version 10.14.6 (18G95). Everytime i try AUTO retopo 3D Coat crashes when i click the third "Next" dialog button.
It does not matter if i choose a very simple shape or not. I get the same crashes on a different Mac Book Pro too. I can export to .obj and run Instant Meshes without problems though.
Is this a known bug?
//Anders
Hi
Hope this help
On 7/1/2017 at 2:20 PM, SERGYI said:
"3D-Coat" crashes because macOS isolates "3D-Coat" executable from its data - typical problem under macOS Sierra. To solve it please do the following:
1. Remove folder "/Applications/3D-CoatV4-7".
2. Make sure that you have checked "System Preferences > Security & Privacy > Allow apps downloaded from: App Store and identified developers" before downloading disk image with "3D-Coat" on your Mac.
3. Download "3D-Coat 4.7.32" for macOS from here and drag & drop it onto "Applications" alias as usually:
In case these 3 steps will not solve the problem then please do these additional steps:
4. In Terminal go into "Downloads" folder:
$ cd ~/Downloads
5. Check extended attributes of downloaded disk image with "3D-Coat 4.7.32".
$ ls -l@ 3D-CoatV4-7-32.dmg
Among them should be "com.apple.quarantine".
6. Delete quarantine attribute:
$ xattr -d com.apple.quarantine 3D-CoatV4-7-32.dmg
7. Check that attribute "com.apple.quarantine" has gone:
8. Remove previous folder "/Applications/3D-CoatV4-7". Open in "Finder" this disk image with "3D-Coat 4.7.32" on which you have removed "com.apple.quarantine" attribute and as usual drag & drop it into "Applications" icon.
I have the same problem with Autopo crashing. I reverted to 4.8.40 as suggested but the crash continued. I have now tried the latest 4.9 beta but still getting the crash. I am working on a Mac Pro 2010 with an AMD RX590 GPU. Mojave 10.14.6. Any suggestions would be appreciated.
 Have you tried another model?
Same as me AUTOPO crashes no matter what you do. Its not even possible to add materials or any addon model..
Maybe they will make this software better in the future but if you have OSX you cant use it as intended as is
By installing old "3DCoat" builds under macOS one-by-one it turned out that between "4.8.38" and "4.8.39" actions "Perform Retopology" and "AUTOPO" had been broken. "3DCoat 4.8.38" is the last build where they are working under macOS (please see attached screenshots):
http://www.pilgway.com/~sergyi/3DCoat/3DCoat-4.8.38.dmg
Currently we are unable to fix them in new "3DCoat" build because for today we have compiled all 1077 source files under macOS and we are going to the second stage of building - linking.
25 minutes ago, SERGYI said:
Testing 4.9.31 under macOS. Sculpting, retopo, baking, and smart materials painting are working.
