Member Erza86 Posted September 24, 2019 Member Report Share Posted September 24, 2019 (edited) hi 3d Coat, i have a problem with new 3dcoat 4.9.03, now when i retopo an object with orthographic camera, the zoom in tool now limited to specific range and making retopo process become hard, and if switch to perspective, the retopo mesh vanished if i zoom in to specific range, i almost not able to finish the job. And the retopo mesh is visible from the back and i can saw it from the back of the mesh my old 3dcoat which is 4.8.20 version is still okay and never have this problem, but i need the new tool from the latest version, is there a way to fix this, my friends said, the problem happen when the object is too small, but this is the default size from zbrush and blender, i can't change the size and i won't resize the mesh 3 to 6 times. thank you Edited September 24, 2019 by Erza86 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 24, 2019 Report Share Posted September 24, 2019 - Edit > Preferences > Viewport Near Plane Modulator Both version have the same value ? - Geometry > Edit Scene Scale > The scene is using default values 0,0,0,1 ? Quote Link to comment Share on other sites More sharing options...
Member Erza86 Posted September 24, 2019 Author Member Report Share Posted September 24, 2019 (edited) nothing happen, the mesh still visible in any direction, but z bias help to reduce the visibility of the mesh, and where is geometry menu? i can't find it also does near plane modulator value can be above 2? thanks edit* it was auto scale button from tool menu after import model from zbrush, everything looks fine, i think when i press auto scale it will change the size of the model, but no, the size is remain same, i export the model after pressing auto scale back to zbrush and the size is not changing, the retopo mesh looks fine, the camera clipping also looks fine still clipping but no problem. so my question is, the scale that tool option mention, what exactly the meaning? is it change the scale of the model or something else? like if 1 meter in blender and after i press auto scale, does it change into 10 meter? or not? if not what scale(in tool option) do for? thanks Edited September 24, 2019 by Erza86 enlightment Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 24, 2019 Report Share Posted September 24, 2019 Sculpt Workspace > Geometry Submenu. 1 Quote Link to comment Share on other sites More sharing options...
Member Erza86 Posted September 24, 2019 Author Member Report Share Posted September 24, 2019 thanks Quote Link to comment Share on other sites More sharing options...
