Very, VERY slow Step Back command.
Hey. For some reason, the Step Back command works terribly slowly (you can wait up to 30-50 seconds) on meshes in 500k + polygon models. This is true for voxels, for the surface I did not check.
For example, using a "Hide Layer" hotkey (hover over the object you want to hide and press the key combination) hides the object, but the "step back" works as slowly as if it were rebuilding a layer-like mesh like an onion, and only then shows the desired mesh.
At the same time, clicking on the characteristic eye next to the layer works without any complaints.
I have i7 6800k, 32 gb RAM, GTX 1080 Ti, and I think it’s strange that on such a powerful computer, such simple things work so strange.
