Kargall
[Solved] Problèm . The PAN is not like before
Hello I have a navigation problem with the stylus,
I feel that there is something changed.
The PAN is not like before:wacko:
Before , for to move in the screen (PAN), the stylus had to touch the wacom then to make a right click then to move (PAN)
Now, I have to make a right click (in the void) (so zoom) and then put the stylus on the screen of the wacom.
This is very unpleasant.
How to return to the default settings of older versions?
Thank you:)
I've had the same issue (also using Wacom), I was sure something in the program changed, but then I thought it was just me getting confused between programs.  Does anyone know did the navigation actually change?
Edited by Falconius
I've noticed this too.  It's very annoying.
17 hours ago, ryivhnn said:
Or did I completely misunderstand what you're doing? (which is highly probable)
It's very likely! lol
I'm talking about the action and behavior of the stylus.
Before:
PAN = Tablet Contact => pushes stylus button
Now :
Pan = no touch on tablet => pushes stylus button (Zoom) => Tablet contact.
It's really very very disagreeable.
And it's impossible to adjust, apparently.
Please Andrew, put the original settings back:sorry:
Thank you very much
Just had a quick look at mine .6 beta works like the .2 beta for me,  absolutely fine .:p:  But Ive got a whole heap of glitches elsewhere .:( So sticking to .2 beta for now.
( wacom Bamboo)
This problem popped up for me right after I updated my drivers (wacom cintiq), so it's probably some new issue to do with compatibility?
I'd really like a solution to this too. It's a tiny inconvenience yet so, so annoying.
Perhaps changing top tablet button to middle click for 3d coat will help everyone in the meantime? I'm trying that out right now.
@Kargall I was able to reproduce the behaviour I think you're describing by turning the nib touch requirement I have set for my CCH for right and middle click off.  I think it's called hover clicks or something like that, could you try turning them off (at least for 3dC) and see if that helps?
I will try this as well.
Hi,
It seems that the problem comes from the pilots:
I reinstalled the WacomTablet_6.3.15-3 drivers and everything works as before.
Thank you very much
