[Solved] Cant see texture preview while painting
Leviosa
Hello, I'm new to 3D coat. I have this problem, I cant see texture preview.  I can't paint over the texture.
For example, in this tutorial https://www.youtube.com/watch?v=pxINVJVbDns
He clicks on some material... and the image overlay appears. When I click on a material no texture overlay appears on the viewport.  I can paint the material but I can't see how exactly it's positioned.
Thank you, I see the difference now.   I'm painting over a low poly model so vertex painting is not an option.
I happened to find a solution to see the texture and paint over it. In the preview options panel I had to change projection to "From Camera"
  • Carlosan changed the title to [Solved] Cant see texture preview while painting
