[Solved] Transform copy tool - paint normal map info from imported image
dexsoft
Whe I use transform copy tool in paint room to paste some amblem onto my model, i select image with emblem, then transform it over model to get good position to paste onto model. Then I press enter and emblem get painted onto model. Sometimes I need that part of that emblem have some indents like letters embrossed in wood. How can I add normal map info to emblem image and gets emblem inserted with some depth info, not only emblem color? Should I make emblem normal map and plugin into some other place which I dont know?
Maybe to use that other spline image tool? But it is hard to position it onto model
Any idea?
  • Carlosan changed the title to [Solved] Transform copy tool - paint normal map info from imported image
