Exported Colour Map Issues
Hi
if you are using Metalness and your paint layer's Metal Opacity is above 0%, then Diffuse will be darkened.  So, you need to export "Color (albedo)" and not Diffuse.  If you are not using Metalness, or your Metal Opacity in your paint layers is set to 0%, then you can export with Diffuse and still receive color information.
