Where is my rendering ?
2 minutes ago, Kargall said:
Hello,
I'm trying to render in 3D Coat but it does not happen.
Nothing in the files
I have to miss something, but what?:rolleyes:
I think there was a fix for that in 4.9.09. As of 4.9.06 there was a TON of refactoring work done, so it's caused some random issues that are being ironed out.
I've been looking at the rendering also. I was very excited about the render, it is odd the way it saves the render ATM. When you save your render, it seems that you are saving your output, but you are creating a folder to place it in. Anyway... only BETA so it'll get some polish soon.
In the version of 3D Coat 4.9.09, which you can already download on the forum, the render results should be saved normally
  • Carlosan changed the title to [Solved] Where is my rendering ?
Looked at the save path 4.9.09 ... I'm still confused by where its saving exactly. If for example I specify the desktop as destination for renders, it seems to put it in a Renders folder?
Tested Depth Pass etc... I still get alot of banding, can't really use it in its current state, again hopefully it will be addressed.
  • Carlosan changed the title to Where is my rendering ?
