Member MetalDevil Posted December 1, 2019 Member Report Share Posted December 1, 2019 (edited) Anyone here good with Blender and got know-how? I used blender to model a bottle, and a cork. When I was done, I exported the model to 3D coat, and retopologized etc. After I was done, I went to the 3D coat store to buy a glass smart material. So, I did as the instructions say to make it look like glass, and I was satisfied with the results. (Lower opacity etc) However, when I export the object back to blender with the results I got from 3D coat, Blender only recognizes the cork material, but not the glass material, and it doesn't look like glass, just a plain model. so I'm not sure what to do. Edited December 1, 2019 by MetalDevil Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 1, 2019 Report Share Posted December 1, 2019 Hope this help Quote Link to comment Share on other sites More sharing options...
Member MetalDevil Posted December 1, 2019 Author Member Report Share Posted December 1, 2019 (edited) Thanks, I will mess around in blender using that video. But theres nothing I can do in 3D coat to keep the glass material/opacity/effect after exporting to Blender, so Blender will notice its meant to be glass? This is the link where I got the glass material. "Procedural glass smart material." https://gumroad.com/michaelgdrs?query=Glass&sort=page_layout#VuDn Edited December 1, 2019 by MetalDevil Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 2, 2019 Report Share Posted December 2, 2019 Both 3DC and Blender use PBR textures, you need to assign the map to every Principled Shader input - See Opacity map ? Use it as the factor of mix shader - Or apply Alpha Blend Quote Link to comment Share on other sites More sharing options...
Member MetalDevil Posted December 2, 2019 Author Member Report Share Posted December 2, 2019 Ok, I will look into that, probably tomorrow. Thanks. Quote Link to comment Share on other sites More sharing options...
Member MetalDevil Posted December 2, 2019 Author Member Report Share Posted December 2, 2019 Looks like those videos and your input helped me do the trick. Thanks Carlosan. 1 Quote Link to comment Share on other sites More sharing options...
