[Solved] cube sphere cylinder stencil mapping in sculpt room
jima
Is there a way to observe the mapping / wrapping of a stencil on the target mesh in full prior to actually transferring brush strokes? with camera view you get to see the stencil much better for things like sizing, rotating, etc. I want to be able to position the stencil exactly against the mesh.
Thanks
Certainly useful information. I think I learned some things and discovered how to see the stencil mapping on the object:
The circled controls in the upper right can be pressed to reveal the stencil mapping. For some of the mapping options, click on settings to see the mapping. Notice the check box in the lower left of the dialog box to Show Preview. Sliders will change the mapping.
  • Carlosan changed the title to [Solved] cube sphere cylinder stencil mapping in sculpt room
