Member OsiyoStudio Posted December 9, 2019 Member Report Share Posted December 9, 2019 running Mac Catalina - every time I try to AUTPO 3DCoat crashes after clicking next in last message box Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 10, 2019 Report Share Posted December 10, 2019 On 12/5/2019 at 3:41 PM, SERGYI said: That build has some problems (commands "UV unwrap" and "AUTOPO" cause "3DCoat" to silently exit). Therefore under macOS try "3DCoat-4.8.40" which is more stable:http://www.pilgway.com/~sergyi/3DCoat/3DCoat-4.8.40.dmg Quote Link to comment Share on other sites More sharing options...
Member OsiyoStudio Posted December 11, 2019 Author Member Report Share Posted December 11, 2019 will try Quote Link to comment Share on other sites More sharing options...
Member OsiyoStudio Posted December 12, 2019 Author Member Report Share Posted December 12, 2019 tried all versions 4.8 to latest beta - nothing works - either hangs or silently crashes - now I'll have to go to the dark side and use Substance Painter Quote Link to comment Share on other sites More sharing options...
SERGYI Posted December 13, 2019 Report Share Posted December 13, 2019 Have you tried to clear quarantine flag from http://www.pilgway.com/~sergyi/3DCoat/3DCoat-4.8.40.dmg? $ xattr -dr com.apple.quarantine /Applications/3DCoat-4.8.40 Quote Link to comment Share on other sites More sharing options...
Member OsiyoStudio Posted December 14, 2019 Author Member Report Share Posted December 14, 2019 program works fairly ok - just crashes every time in try to AUTPO - even a simple share Quote Link to comment Share on other sites More sharing options...
Member OsiyoStudio Posted December 19, 2019 Author Member Report Share Posted December 19, 2019 So I guess no one else has this problem? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 20, 2019 Reputable Contributor Report Share Posted December 20, 2019 On Windows (4.9.15) it works great. I just used it to Auto-Retopo over a dozen parts and no crashes. Did you test it on a scene from the splash screen or new blank scene, with a primitive? That would help indicate whether it is a problem with the Voxel object underneath or with the application. Trying to underestimate the Polycount can cause problems....like trying to estimate a 1000 polys on a shape that needs 5000 (as an example) or more to account for all the different contours and details. If you have voids or pockets inside an object, that can cause problems. It's why it's a good idea to RMB the layer and click FILL VOIDS on Voxel objects. This has been mentioned in many Auto-Retopo videos. Quote Link to comment Share on other sites More sharing options...
New Member DragoCG Posted January 6, 2020 New Member Report Share Posted January 6, 2020 3D coat keeps crashing on me as well when trying to do basic retopology. I can't even import my FBX. It keeps giving me the warning that it's too big, but everything is in the 0-1 space. I even did auto-mapping on every object first and scaled everything down to fit. I also tried the most recent version and that crashed, so I tried your advice on using 4.8.4, but that keeps crashing as well. My model was created in Maya and is all quads and is under 10k faces. I originally had an older version running, but it started getting buggy, so I tried to update. Now I can't get it to work at all. Any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
SERGYI Posted February 16, 2020 Report Share Posted February 16, 2020 By installing old "3DCoat" builds under macOS one-by-one it turned out that between "4.8.38" and "4.8.39" actions "Perform Retopology" and "AUTOPO" had been broken. "3DCoat 4.8.38" is the last build where they are working under macOS (please see attached screenshots):http://www.pilgway.com/~sergyi/3DCoat/3DCoat-4.8.38.dmg Currently we are unable to fix them in new "3DCoat" build because for today we have compiled all 1077 source files under macOS and we are going to the second stage of building - linking. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 17, 2020 Report Share Posted March 17, 2020 macOS Catalina [4.9.41]: http://www.pilgway.com/~sergyi/3DCoat/3DCoat-4.9.41.dmg "3DCoat" for macOS has been signed and notarized with Apple. Ensure to check "System Preferences > Security & Privacy > General > click the "lock" > select "App Store and identified developers". When only the "App Store" is selected an error message is displayed "3DCoat-4.9.xx.dmg" can't be opened because it was not downloaded from the App Store. Your security preferences allow installation of only apps from the App Store. Quote Link to comment Share on other sites More sharing options...
