[Solved] Back in my corner...
Catherine3678a
One question per post I gather, okay.
I'm used to working in "one room" ... I appreciate that there are several "rooms" in 3D Coat however the fact that the article one is trying to work on keeps vanishing is rather annoying.
Now, in one room there are these nifty meshes? to add ... specifically chains. One clicks along and a nice length of chain link grows.
Steps please: How to get a length of chain from said point of creation to an exportable .obj file that one can see in other programs. tia
Hi
You are working on Sculpt Room using surface mode and added one splines using the model chain, right ?
Then on Tool Option panel first need to press apply.
Second on Sculpt Tree press RMB over the layer end select Export
Hope it help
  • Carlosan changed the title to [Solved] Back in my corner...
