Advanced Member micro26 Posted December 11, 2019 Advanced Member Report Share Posted December 11, 2019 (edited) Can remove stretching have a collapse effect? Something similar to blender dyntopo mode with subdivide and collapse. Remove stretch works great when adding but if the brush is negative it creates artifacts. I use a claybuild brush from presets and ignore backfacing has no difference. A second small request is uppon shift smoothing to use a different stroke type for smooth (very usefull). Thank you. Edited December 11, 2019 by micro26 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 12, 2019 Reputable Contributor Report Share Posted December 12, 2019 It remeshes so it might. Try POWERFUL SMOOTHING from either the SHIFT or SHIFT + CTRL list menu at the top of the UI. It pretty much remeshes beneath your brush while smoothing. It's really good for trouble spots. Quote Link to comment Share on other sites More sharing options...
