New Member akitaland13 Posted December 12, 2019 New Member Report Share Posted December 12, 2019 By using sculpt brush and smooth brush in voxel mode Artifacts have appeared on the surface of the object. Unnatural patterns are recognized even in surface mode. Please check pic and video. https://1drv.ms/u/s!AkLv9Kt8XCebgTv7VKh3fgSFdLGJ?e=wnaqPH https://1drv.ms/v/s!AkLv9Kt8XCebgTk_4oHlivzBsKY8?e=tgkVbE I also uploaded the 3b file. https://1drv.ms/u/s!AkLv9Kt8XCebgTqggqS1laADO7Bq?e=FfgB9O I used 4.8.20 normally, I remember that artifacts began to occur after installing 4.9.12. After confirming the symptoms, I reinstalled all 3d-coat applications. I tried DX and GL versions 4.7.37, 4.8.20 and 4.9.12 respectively, but the results were the same. The video card driver has also been updated to the latest version. (GeForce Game Ready Driver 441.66) os - windows10 64bit cpu - intel core i7-8700 3.20GHz memory - 16GB RAM DDR4 motherbord - TUF H370-PRO GAMING video card - Nvidia GeForce GTX 1050 Ti These sentences were translated by google automatic translation. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 12, 2019 Report Share Posted December 12, 2019 Hi Using another shader the result shown is similar ? Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted December 12, 2019 Applink Developer Report Share Posted December 12, 2019 Turn off cavity and see if that helps. Quote Link to comment Share on other sites More sharing options...
New Member akitaland13 Posted December 12, 2019 Author New Member Report Share Posted December 12, 2019 Thank you for your reply. Some shaders caused artifacts and some did not. I ’ve verified that the “use cavity” is turned on in the shader settings. It seems to bring an artifact. So I use shaders that don't use cavities, or By turning off the shader cavity I use, I think it will be a first aid. However, it seems that something wrong is happening with the unedited default shader right after reinstalling 3d-coat. To reinstall 3d-coat cleanly. I moved 3d-coat related folders from My Documents folder and program files folder to another location. Is there anything else I should delete? Thank you. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 12, 2019 Report Share Posted December 12, 2019 For migration from old installs, is better to use Migration Master Quote Link to comment Share on other sites More sharing options...
New Member akitaland13 Posted December 13, 2019 Author New Member Report Share Posted December 13, 2019 Thank you for the reply. The fact that installing these older versions does not fix these symptoms may not be the fault of the software. Probably because of an unknowing change in my PC environment. First of all, I will use it with the cavity off. I will use the immigration tool when I need it. I will try it out when a new beta comes. Thank you again! Quote Link to comment Share on other sites More sharing options...
