Member Kevin360 Posted December 16, 2019 Member Report Share Posted December 16, 2019 Hello, Sorry if my english is not perfect. I am French. I use 3D Coat to make 360° illustrations by drawing on a sphere. Since the last update, some areas cannot be covered when I paint over it. They seem to correspond to the edges of the faces. Can you help me ? Thank you! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 16, 2019 Report Share Posted December 16, 2019 Hi ! Is a know bug. If you paint any stroke over a seam get that error. Dev team is working on it. Quote Link to comment Share on other sites More sharing options...
Member Kevin360 Posted December 16, 2019 Author Member Report Share Posted December 16, 2019 Okay. Thank you for your answer. It's weird, it works until 3DCoat-V4.9.05 and it doesn't work after that. Quote Link to comment Share on other sites More sharing options...
Member Kevin360 Posted February 15, 2020 Author Member Report Share Posted February 15, 2020 @Carlosan It's not fixed yet, is it? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 15, 2020 Report Share Posted February 15, 2020 4.9.23 i found it fixed. Remember: you can have several versions installed at the same time. Quote Link to comment Share on other sites More sharing options...
Member Kevin360 Posted July 13, 2020 Author Member Report Share Posted July 13, 2020 Hi Carlosan, Thank you very much for taking the time to help me. I still haven't solved the problem. The only version that works is the 3DCoat-V4.9.05. I have tested many versions, including the latest V4.9.54 but the problem is the same. Can you try with this file > https://we.tl/t-G60lT1XrPO ? If the problem is my sphere, how can I recreate a sphere with an equirectangular UV like my attached file? Thank you very much! Quote Link to comment Share on other sites More sharing options...
Featured Comment Carlosan Posted July 13, 2020 Featured Comment Report Share Posted July 13, 2020 Test this project please sphere.zip Quote Link to comment Share on other sites More sharing options...
Member Kevin360 Posted July 14, 2020 Author Member Report Share Posted July 14, 2020 Perfect ! I just changed the width of the texture so that it is twice the height (5000 x 10 000 pixels) Thank you very much for your help and your responsiveness 1 Quote Link to comment Share on other sites More sharing options...
Member Kevin360 Posted November 17, 2020 Author Member Report Share Posted November 17, 2020 Hi Carlosan, Can you create a sphere with an equirectangular texture of 5 000 x 10 000? The texture of the sphere you sent me is square and I failed to convert it to equirectangular format. I would like to thank you, tell me your price for doing that Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 17, 2020 Report Share Posted November 17, 2020 Hi Kevin Let me try it ASAP Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 17, 2020 Report Share Posted November 17, 2020 Sorry but im am afraid my test failed You can set custom resolutions using Textures > Mesh & Texture Resolution, But i dont know why there is a pixel space in between seams -are not tiled correctly- Please drop a mail at andrewshpagin@gmail.com asking for support Thx Sphere2.zip Quote Link to comment Share on other sites More sharing options...
Member Kevin360 Posted November 17, 2020 Author Member Report Share Posted November 17, 2020 Thank you very much for your help Carlosan I will contact Andrew and give the solution here if it exists. 1 Quote Link to comment Share on other sites More sharing options...
Member Kevin360 Posted November 25, 2020 Author Member Report Share Posted November 25, 2020 I contacted Andrew. This problem is fixed in version V4.9.67 ! Thank you Carlosan :) 1 Quote Link to comment Share on other sites More sharing options...
Posted by Carlosan,
0 reactions
Go to this post
