dexsoft
Bake with smoothing angle not recorded in normal map
When I have retopo model and want to transfer it to paint room (without baking normal map) with only smoothing angle, or with marking sharp edges I get prefect model in paint room.
Depend on smoothing angle I get nice smooth round part just like I do with standard baking high to low poly. Only problem when I export model that info it is not recorded in normal map.  How can I bake that info from paint room onto exported normal map. When I use exported model in unity it is ok because I can control there also roundness with smoothing angle and hard edges, but I need this info into normal map
Edited by dexsoft
Yes I always calculate curvature, and then occlusion. Like good trick I double curvature map and mark it like overlay and that way I get great nice edges
On second thought, If you select no baking option, there is no reason for normals to be baked even with smoothing groups on. So you should try to go with bake normals and it will work. I think its by design.
Yes I thought so :(
Maybe there is a way to bake this nice roundings and sharp edges made via smoothing groups into normal map from paint room.
Texture Baking Tool could be a solution, you only need to bake High poly to low poly
