New Member bitbetter Posted January 14, 2020 New Member Report Share Posted January 14, 2020 hello when I change the brushes that are attached to the hot keys, the transparency value in the eraser tool is reset to zero. The solution is to manually go to the eraser tool to set the transparency value to 100 and switch to brush mode, manually rather than hotkey I wanted to see the value of transparency constant, how can I do this? Quote Link to comment Share on other sites More sharing options...
