How to select multiple objects in the viewport?
AntonTenitsky
Go to solution Solved by mode11,
  • 2 years later...
Hello,
I am having the opposite issue at the moment - quick pick seems to be constantly adding selections. How exactly does one control these two behaviors ? Ideally I'd love to be able to do all kind of complex selections directly in viewport, without having to touch the outliner ...
Edited by pior
  • 8 months later...
  • New Member
I'm having the same issue as Pior - selecting objects in the viewport with Quick Pick just keeps adding to the selection. Selecting in the Outliner works as expected. It's only recently started doing this for me. I'm on the latest version (2023.28), which I installed a couple of days ago.
Edit: restarting 3DC fixed the issue.
  • New Member
  • Solution
Thanks for the tip, but that caused the issue to start happening again. I think I must have tried using this shortcut previously (perhaps to hide / unhide something). Is there a way to turn this feature off again, without just resorting to restarting the app?
Edit: found it. Choose Pick Current Layer (H), rather than Pick Layer Add, at bottom of Windows > Panels.
