Member AndrewG Posted February 16, 2020 Member Report Share Posted February 16, 2020 Hi, I want to use in my model some subtractive obj model (from here: https://gumroad.com/l/GTbjm). When I choose one of the 3d models from this pack and I set "On Brush" in "Import tool" option I can see that this object is far beyond center of the brush. It is impossible for me to precise place the object where I want. I tried to fix it by going into "transform" place option and play with scale and axis, but when I returned into On brush option again nothing changed. Is there something wrong I`m doing? This is strange, because when I start new file with some basic cube everything seems to be fine. So propabally I set something off in my scene settings but I`m not sure where to find it. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 17, 2020 Report Share Posted February 17, 2020 Hi Which version are you using ? Latest one ? Quote Link to comment Share on other sites More sharing options...
Member AndrewG Posted February 18, 2020 Author Member Report Share Posted February 18, 2020 Hi Carlosan, Sorry to bother you. I found a simple solution. I had to reset scene scale ("Geometry" menu > Edit Scene Scale > set everything to 0) and it worked as it should. 1 Quote Link to comment Share on other sites More sharing options...
