New Member Pavel.Post Posted February 16, 2020 New Member Report Share Posted February 16, 2020 Hi, I've recently switched from 4.9.1 to .17 and immediately run into an issue with using a shortcut for clone or delete action. When I'm trying to clone a vox layer using any defined shortcut, it seems that at random it will clone either one higher level in the vox tree, or the whole vox tree, as if I have the whole vox tree selected in the sculpt tree window. The same happens with delete action. Using the right click menu works properly. I have no issues with other 3dcoat versions. While I'm at it, I have another more general issue - Some shortcuts don't carry over with the hotkey backup file between version. Is there any way to bring all shortcuts in? Thanks! Pavel Log.txt PavelPost_16_2_2020_v4.9.17.txt Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 16, 2020 Report Share Posted February 16, 2020 Hi Please try the same workflow using latest version 4.9.26 Some issues were fixed. Edit > save/load Hotkeys was working fine in-between version, but some changed was done with latest ones. You need to add it manually. Quote Link to comment Share on other sites More sharing options...
