4.9.17 Clone / Delete vox layer affects higher voxtree level
  • New Member
Hi, I've recently switched from 4.9.1 to .17 and immediately run into an issue with using a shortcut for clone or delete action.
When I'm trying to clone a vox layer using any defined shortcut, it seems that at random it will clone either one higher level in the vox tree, or the whole vox tree, as if I have the whole vox tree selected in the sculpt tree window. The same happens with delete action.
Using the right click menu works properly.
I have no issues with other 3dcoat versions.
While I'm at it, I have another more general issue - Some shortcuts don't carry over with the hotkey backup file between version. Is there any way to bring all shortcuts in?
Thanks!
Pavel
Log.txt
PavelPost_16_2_2020_v4.9.17.txt
