Modeling
Ilas
Привет. Как создать купол из шара. То есть снять внутреннюю часть шара и оставить толстую оболочку. Чтобы сделать его похожим на банку.
14 hours ago, Carlosan said:
Hi
Try Primitives > Lathe
Я думаю, что это даст вам лучший результат
I've looked on 4.9.22 and 4.9.26 and I don't have Primitives.
This is what happens when you're out of the loop for a long time.
15 hours ago, Ilas said:
How can free space be created inside an object?
I would click on the object (in this case the dome) and then select extract shell. You can select at that time the thickness of the shell you want in voxels then when the vessel is hollow slice off the side you want open. That's what I did with this teacup.
@Ilas  View > Backface Culling on will help to visualization.
I saw your version is very outdated. Please can you try using this version ?
http://3dcoat.com/files/3dcoat/V4.8/3d-Coat-V4_8-44-64.exe
Are OS and graphics drivers uptodate ?
* 4.9.26 cant replicate this issue. Sorry i am using another version, i know.
Aha right click on Objects banner at the top of the list of tools and click on  show all objects or restore all objects when the drop down appears.
I wonder how that got hidden? hmm.. That Custom UI trick is a good one though. I'm going to hide away a lot of the tools I rarely use.
Thanks Carlosan.
