Advanced Member Gary Dave Posted March 11, 2020 Advanced Member Report Share Posted March 11, 2020 (edited) I'm surprised it's taken me this long to notice, but it seems you can only keep an objects local axis if the centre of its mass was created at 0,0,0 without any rotations. So if you're following a reference and have to create primitives in different places, you immediately lose a lot of symmetrical benefits. Here's an example: Left = current default behaviour. Right = what I would like the behaviour to be when creating an object. The only workaround at the moment is to create each piece as you need it, making sure it's matching your reference planes, and then reset its position and axis before applying it, then applying it and moving it back to where you had it before. Mind boggling! I don't know if this is just a recent issue, or maybe it's always been like this, or if most of my work up until now has never needed this. But I am now discovering that most of the blockout work I've done over the last 2 days will need to be re-done, because I need to keep the objects local axis in place. On the other hand, I'm reeeaaally hoping that maybe I'm missing something and being stupid. I'm using version 4.9.17 Edit: Oh I should mention that I am well aware of the symmetry options like "Pick from bound box" but that does not work if your objects have rotations. Edited March 11, 2020 by Gary Dave predicting someones solution. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 11, 2020 Report Share Posted March 11, 2020 Let me check Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 12, 2020 Report Share Posted March 12, 2020 I enabled symmetry, moved the center to nonzero location, transformed. Symm planes were transformed correctly as expected. Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 12, 2020 Author Advanced Member Report Share Posted March 12, 2020 But had you already created the object? Because sure if I create the object at 0,0,0 without rotations and then move it, everything is fine. What I'm trying to do is not create all my objects at 0,0,0, I would like to create them where I need them, and to have them keep their local axis. Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 12, 2020 Author Advanced Member Report Share Posted March 12, 2020 Hopefully this video shows what I'm talking about: The first example (in the first 20 seconds or so) is creating an object at 0,0,0 and without rotations, so everything is fine. The second example shows the problem: Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 12, 2020 Author Advanced Member Report Share Posted March 12, 2020 Sorry for the replies! I also see no difference when using the Global Space or Local Space option in the symmetry popup. Quote Link to comment Share on other sites More sharing options...
Advanced Member pickers Posted March 12, 2020 Advanced Member Report Share Posted March 12, 2020 You are right! The local space doesnt work (4.9.28). If i am not wrong, the local space alignment should be based similarly to "main axis in transform". The general case is pretty hard to get it correctly aligned. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 12, 2020 Report Share Posted March 12, 2020 version 4.9.29 From my side is working fine (before any transform i used pick1 command) Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 12, 2020 Report Share Posted March 12, 2020 Another example Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 12, 2020 Author Advanced Member Report Share Posted March 12, 2020 Isn't the "Pick 1" used to set the position only of the symmetry manually? I will have a look for the 4.9.29 download and see if it works for me. Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 12, 2020 Author Advanced Member Report Share Posted March 12, 2020 Okay so I just tried 4.9.29 and it's the same problem. Fresh install of 4.9.29, new scene, new layer: Just to clarify: First object (sphere) shows root position creation = All is fine. Second object shows non-root creation position, also scale/rotation differences. = Cannot get symmetry to align with what should be this objects local axis. Third object = same as second, but created at the root, and then moved. = All is fine (except for the fact that you have to make all your objects at the root) For the "Pick 1" option, I do not see how it helps. Am I missing something? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 12, 2020 Report Share Posted March 12, 2020 Exactly, because need to be children of first object. I usually create an empty layer (V or S, dont care) and put all my models below hierarchy as children's. Symmetry settings are not globally assigned but by layer. Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 12, 2020 Author Advanced Member Report Share Posted March 12, 2020 Hmm, I've just tried that but got the exact same (wrong) results. I have a strong feeling that my issue is not being understood, or I am not explaining it well enough. Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 12, 2020 Author Advanced Member Report Share Posted March 12, 2020 (edited) One more video, this is the best I can explain it: Edited March 12, 2020 by Gary Dave Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 12, 2020 Report Share Posted March 12, 2020 Yes, now I see the problem more clearly. Thx Always i put the model on Global Scape, activate symmetry and then apply transform. From what I see, reversing the steps causes inconvenience. Reported. Thx. 1 Quote Link to comment Share on other sites More sharing options...
