Wrap tool and Bend tools lack of detail instruction how to use it
GrzegorzWięcek
Go to solution Solved by sprayer,
I try to follow  Sandor Veres Allexr  tire wheel tutorial, but he use older version of 3DCoat, an I use 4.9.25 and 4.9.30.
In 1.41 he uses Warp tool. But I can't completetly follow his steps.
My warp works completely different then his older version (look at images attached bellow)
Besides, when I select  sculpt layer I'm working on I face another issue (looks like a bug too, look at attached images, and desriptions in titles).
But when I select any other layer and then choose Warp tool, everything works fine.
Could someone explain how Warp tool work.
Any latest manual how to use Warp tool?
Thak you I hope I explained it clearly ;)
  • Solution
Carlosan
sprayer was awarded the badge 'Helpful' and 1 points.
set angle like this and rotate axes. bend works in similar way, you need rotate axes
But it looks bake on layer option also broken, and after applying undo you need to hit twice)
