Member giobianco Posted March 28, 2020 Member Report Share Posted March 28, 2020 Hi, in version 4.9.34 ... if I combine two levels where the upper one has a "smart material" like dust / scratch or similar ... the result is different from having separated them, in fact strange defects are created (I attach the screen) I had already encountered a similar problem in version 4.9.17 , they said it was solved, but it is still present. sorry for bad english thanks Giovanni Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 28, 2020 Report Share Posted March 28, 2020 Hi As i answered before, found it solved on latest version 4.9.35 Could you please try it ? Thx Quote Link to comment Share on other sites More sharing options...
Member giobianco Posted March 28, 2020 Author Member Report Share Posted March 28, 2020 Ok, I unload and try it...... the version 4.9.35 is beta? is this correct? thanks Quote Link to comment Share on other sites More sharing options...
Member giobianco Posted March 28, 2020 Author Member Report Share Posted March 28, 2020 I tried version 4.9.35 but the problem is still present.. Giovanni Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 28, 2020 Report Share Posted March 28, 2020 I cant replicate this issue, sorry let me ask dev team how to resolve it Quote Link to comment Share on other sites More sharing options...
Member giobianco Posted March 28, 2020 Author Member Report Share Posted March 28, 2020 OK thanks,..! I await answers about it Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 28, 2020 Report Share Posted March 28, 2020 Which is latest version you are working without this issue ? Try switching off Depth channel, Could you share the result ? thx Quote Link to comment Share on other sites More sharing options...
Member giobianco Posted March 28, 2020 Author Member Report Share Posted March 28, 2020 in the 4.5 version it surely worked but it is definitely old ... maybe also on the 4.7 but I don't remember I used it a little .. probably the version before 4.9.17 worked .. since I had encountered the problem with that version ... Today's screens I sent had the depth channel disabled. Strange that you cannot reproduce the problem, the action is very simple ... I create a layer with a base color (layer 1), then I create another layer with the "smart material" "scratches_steel" (layer 2). .. keeping the two separate layers everything works ... but as soon as I join the (level 2) of the scratches on the (level 1) underlying the base color ... it creates those artifacts. thx Quote Link to comment Share on other sites More sharing options...
Member giobianco Posted March 28, 2020 Author Member Report Share Posted March 28, 2020 also on version 4.9.05 it has the same problem ... probably then it was suall 4.8.37 but that I no longer have installed Quote Link to comment Share on other sites More sharing options...
Member giobianco Posted April 6, 2020 Author Member Report Share Posted April 6, 2020 the problem is also present on version 4.9.37 Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 9, 2020 Report Share Posted April 9, 2020 Fixed in 4.9.38 (actually re-downloading 4.9.37 will fix the issue) Quote Link to comment Share on other sites More sharing options...
