[Solved] Treat materials as separate textures - only one UV Set ?
TominoKa
Go to solution Solved by Carlosan,
I am importing an FBX file with multiple objects and multiple materials (unique material per object) for UV unwrapping. I check "Treat materials as separate textures". After import there are multiple Surface Materials (they are the materials I set up in C4D before export) but there is only one UV Set, so all UVs are on one island. On import options is says that it creates separate UV Sets for each material but then there is only one UV Set. I have attached print screens.
  • Carlosan changed the title to [Solved] Treat materials as separate textures - only one UV Set ?
