Member inache Posted May 9, 2020 Member Report Share Posted May 9, 2020 Здравствуйте, подскажите возможно ли решить данную проблему? При нанесение материала на модель, в некоторых местах на её стыках остаются пробелы. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 9, 2020 Report Share Posted May 9, 2020 Hi Try setting padding Preferences Quote Link to comment Share on other sites More sharing options...
Member inache Posted May 10, 2020 Author Member Report Share Posted May 10, 2020 this method does not work Quote Link to comment Share on other sites More sharing options...
Member inache Posted May 10, 2020 Author Member Report Share Posted May 10, 2020 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 10, 2020 Report Share Posted May 10, 2020 Can you share the model to take a look ? Are you using latest version ? Quote Link to comment Share on other sites More sharing options...
Member inache Posted May 10, 2020 Author Member Report Share Posted May 10, 2020 Attached file. Program version 4.5. AWP.obj Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 10, 2020 Report Share Posted May 10, 2020 As i can see (opening on external app) Model is not on global space 0,0,0 (that shouldn't be a problem) UV islands are not on UV space 0,0 (that shouldn't be a problem) Island are overlapped = paint strokes/fills are overlapped Use this settings at import to paint over 2 separated Surface Materials without overlapped Uvs Hope it help Quote Link to comment Share on other sites More sharing options...
Member inache Posted May 10, 2020 Author Member Report Share Posted May 10, 2020 Thanks for your help and quick reply. I will try. Quote Link to comment Share on other sites More sharing options...
Member inache Posted May 11, 2020 Author Member Report Share Posted May 11, 2020 Thank you for your help. But the problem has not been solved, the result is the same (((((I really liked the program, but with such a problem I will have to look for a replacement Quote Link to comment Share on other sites More sharing options...
Member inache Posted May 11, 2020 Author Member Report Share Posted May 11, 2020 I determined that this problem is not related to the program !!! It's all about the model itself 1 Quote Link to comment Share on other sites More sharing options...
Member inache Posted May 11, 2020 Author Member Report Share Posted May 11, 2020 I found out: if you set auto-mapping when you open the file, the result of the drawing is very good and no gaps when painting stitches. But at the same time, the UV mapping changes a lot((((I can’t change it). Maybe there is a solution that will not affect the existing UV? What version of the program did you use to open my file? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 11, 2020 Report Share Posted May 11, 2020 Version 4.9.42 Quote Link to comment Share on other sites More sharing options...
