Member John Kearney Posted May 11, 2020 Member Report Share Posted May 11, 2020 Hello, I have a single object with multiple, disconnected parts. I would like to use Vertex Painting and fill them all without clicking each one manually. I have tried both 4.9.36 and the latest Beta (4.9.42) but no luck. Is the behaviour in the attached video expected? Any help much appreciated! Thank you. John FillTool.mp4 Quote Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted May 11, 2020 Advanced Member Report Share Posted May 11, 2020 If you click the Layer checkbox in the Tool Options box you have open in the video it should do the trick. 1 Quote Link to comment Share on other sites More sharing options...
Member John Kearney Posted May 11, 2020 Author Member Report Share Posted May 11, 2020 (edited) Hi Stu, Thanks for replying! Unfortunately, clicking Layer doesn't work either. The only way I appear to be able to fill in Vertex Paint mode is to directly click any objects. I've even tried right-clicking the layer and selecting fill layer but no luck. I should also probably confirm that Fill Layer/Object both work fine when using per-pixel painting with UVs. Thanks anyhow! John Edited May 11, 2020 by John Kearney Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 11, 2020 Report Share Posted May 11, 2020 Try RMB over the paint Layer > Fill entire layer using current material and color 1 Quote Link to comment Share on other sites More sharing options...
Member John Kearney Posted May 12, 2020 Author Member Report Share Posted May 12, 2020 9 minutes ago, Carlosan said: Try RMB over the paint Layer > Fill entire layer using current material and color Hi, I have tried this but no luck. The behaviour is very strange. I have recorded another video for you if you could please take a look! Thank you, John 2020-05-12 01-04-42.mp4 Quote Link to comment Share on other sites More sharing options...
Advanced Member pickers Posted May 12, 2020 Advanced Member Report Share Posted May 12, 2020 the shading looks weird in sculpt room. Inverted normals? Does selecting the different shader in sculpt room help? Quote Link to comment Share on other sites More sharing options...
Member John Kearney Posted May 12, 2020 Author Member Report Share Posted May 12, 2020 6 hours ago, pickers said: the shading looks weird in sculpt room. Inverted normals? Does selecting the different shader in sculpt room help? Hi, the normals aren’t inverted, it’s just that they are boxes/cubes using one smoothing group so it’s making them look blobby. I’ve tried changing shaders but it makes no difference unfortunately. Quote Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted May 12, 2020 Advanced Member Report Share Posted May 12, 2020 (edited) Thats all weird isnt it. Clicking the Layer option is the way to go. So you have something going on there, its just finding the problem. Have you tried makeing a complete fresh scene just to see if it does actually work. Maybe a corrupted file. ( am I right to assume your boxes are not your actual scene but just a simple demo of it not working?) It sounds like something beyond my simple detection abilities. Maybe you could post the scene so the techies can get their teeth into it. Edited May 12, 2020 by stusutcliffe typo Quote Link to comment Share on other sites More sharing options...
Member John Kearney Posted May 12, 2020 Author Member Report Share Posted May 12, 2020 Yep, the boxes were made just to test it (it wasn't working in my proper scene so thought something there may be the issue). It doesn't even work for me if I create the boxes directly within 3DCoat so I suspect something is wrong with my settings but I have no idea what - especially as I installed the latest update and reset my settings from the Edit menu. I'm totally stumped! Quote Link to comment Share on other sites More sharing options...
Member John Kearney Posted May 12, 2020 Author Member Report Share Posted May 12, 2020 Right, something bizarre just happened and it was caught on video luckily! It is self-explanatory so please check out the video - clearly shows it must be a bug? I immediately undid the one successful fill, and then couldn't do it again! Tried reproducing the steps but no luck. It's all very confusing. 2020-05-12 12-20-20.mp4 Quote Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted May 12, 2020 Advanced Member Report Share Posted May 12, 2020 (edited) Somewhere in your program folder/folders there is a setting/file called Options.xml, deleting this is sometimes recomended by folks to cure a number of ills. I think it just makes itself again a fresh when its deleted but it sort of clears out some rubbish. I dont really understand the under the hood stuff, maybe try this. Or if some techie could explain if this is a good/bad idea or not. See piccy But wait to see if anyone has a thought about this. Edited May 12, 2020 by stusutcliffe added image Quote Link to comment Share on other sites More sharing options...
