Member inache Posted May 14, 2020 Member Report Share Posted May 14, 2020 (edited) Hello! Tell me, please, why, when previewing, the clarity of the texture differs from applied to the model ??? Edited May 14, 2020 by inache Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 14, 2020 Report Share Posted May 14, 2020 Hi ! The preview window renders at a Higher quality. You would need a 8k map in the smart material to closely match it. You will be limited by the resolution of the smart material images that are used to make the smart material and your final texture resolution for your image maps. Also is how well you are using the UV space, that is how your uv-islands are filling up the uv space. I make all-my smart materials at 4K. Quote Link to comment Share on other sites More sharing options...
Member inache Posted May 14, 2020 Author Member Report Share Posted May 14, 2020 Understand you. Thanks for the answer. 1 Quote Link to comment Share on other sites More sharing options...
