hose
Failed to read multiple objects and normal map
I have read the UV-developed object in MAYA.
All UVs are deployed in the first place.
Is this all right?
In 3D Coat, only the UV of the head is displayed.
Should all clothes be UDIM from body?
next
I made multiple normal maps with zbrush.
I have read the second normal map.
It had an unexpected effect.
I want to read and paint all the character parts.
How can I make it come true?
Hi
How many uvsets, separated models, materials do you have ?
Try exporting as fbx, and import in 3DC using this settings
Hope it help
Thank you for your reply.
Will I make 11 fbx?
Or Am I using Combine to load it into a single object?
Or Do I have to create a UDIM for every object?
And what items does fbx need?
Do you need to paint 11 objects at same time ?
if not... can paint every mesh individually ?
I want to paint 11 objects at the same time.
I think it's easier to see if I paint all at once.
Edited by hose
Export selected as 1 fbx and import in 3DC using this settings
I converted it to fbx format.
I have successfully loaded multiple objects.
Thank you very much.
However
I loaded 3 normal maps made with zbrush.
An unexpected pattern appeared.
On ZBrush was flipped on Y before export ?
[On Z Brush was flipped on Y before export?]
yes
The normal map creates the unevenness that I expected.
I think it's a problem because I'm loading three normal maps.
Objects are displayed overlapping.
Texture > Import > Normal map
have you assigned the specific NM to every UVset ?
I have successfully equipped a normal map.
But,
Multiple objects (fbx)
At this time, the selection of UV set is not displayed.
↑ This is not displayed on the screen
If I load a separate object in obj I get a UV set selection.
Should I add it with [import object]?
