pr1970
[Solved] 3dcoat issues with fbx face normals
Hi All,
Noticing that this fbx i`m trying to import is having alot of issues.
It doesnt have decent uv`s so its doing an auto-map on import. But it just doesnt understand the face normals. I tried the same object in Maya, blender and cinema 4d without any issues. But 3d coat just fills it with holes. Tried all combinations of settings, weld vertices, invert normals, lock normals,etc but nothing works.
Any suggestions?
Thanks
Export it as fbx 2014
Hope it help
Thanks but no difference. I tried triangulation and merging vertices before saving as 2014 fbx. I tried a range of software, only packages with issues are knald and 3d coat. The rest just worked with the original, there are some n-gons in there but like i say , even clearing them up i couldnt get it to load properly in 3d coat.
Edited by pr1970
Are you using latest version ? Upgrades to fbx file format were done.
Did you try importing it as obj ?
or can you share (pm) the model to take a look ?
Sorry, didnt have notify on. v4.9.49 (latest beta)
I tried an obj that i exported in from blender, but still had the same issues. I`ll PM you the model.
Thanks
Hi
I am reporting this as bug.
Same as you tried all combinations of settings, weld vertices, invert normals, lock normals, etc but nothing works.
Thx for point it up
Only when i triangulate all mesh parts (outside 3DC) model loads fine, but show lot of issues on the original mesh -ngons and double vertices-
Yeah it has some issues that model, its not mine but wanted to try some quick tests in 3d coat and another mesh were loading it with lots of issues.
Only when i tried other packages that all seemed to deal with those problems that i was a bit concerned with 3d coats handling.
