New Member anton lazakov Posted June 14, 2020 New Member Report Share Posted June 14, 2020 Добрый день, спасибо за ваш продукт, 3d Coat давно стал частью моего профессионального пайплайна! К сожалению после обновлений у меня перестали работать Vertex Lasso, Stroke Lasso, Closed Spline после активации симметрии (в рабочем пространстве Sculpt). Сегодня я установил последнюю версию с вашего сайта, но инструменты по прежнему работают некорректно. Последняя стабильная версия на которой мне приходится работать - 4.9.05. Буду очень благодарен, если вы поможете мне с решением моей проблемы, которая преследует меня уже больше года. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 14, 2020 Report Share Posted June 14, 2020 Hi if you are not using the steam version and like to try, in the last version all these problems are solved. Quote Link to comment Share on other sites More sharing options...
New Member anton lazakov Posted June 16, 2020 Author New Member Report Share Posted June 16, 2020 On 6/14/2020 at 5:23 PM, Carlosan said: Hi if you are not using the steam version and like to try, in the last version all these problems are solved. Thanks for the answer Carlosan! You suggest me to use build 4.9.01, but I use 4.9.05 in work (this is a later version and it is stable). Does this mean that I can continue to use version 4.9.05 further? And the second question, when should I wait for an update that would fix a bug with symmetry? I like the changes you make in the program, but because of a bug with symmetry, I can’t use later builds ( Quote Link to comment Share on other sites More sharing options...
Member TanKh Posted June 16, 2020 Member Report Share Posted June 16, 2020 my russian language is not sufficient to read exactly what he said but I struggle with splines and symmetry as well. I am currently using Beta 4.9.45 but this happens with older betas as well. Quote Link to comment Share on other sites More sharing options...
Member TanKh Posted June 16, 2020 Member Report Share Posted June 16, 2020 update: right part is done with Splines and some manual painting. The left part is the unedited result of using symmetry. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 16, 2020 Report Share Posted June 16, 2020 Sorry i am testing last version v4.9.49 but cant replicate this issue Quote Link to comment Share on other sites More sharing options...
Member TanKh Posted June 16, 2020 Member Report Share Posted June 16, 2020 Thanks for your efforts @Carlosan. I updated to 4.9.49 and found no difference so I tested around a bit. The amount of errors seem to depend a lot on the view angle when applying the spline. When projecting on the arms it works when viewing from above. But for the legs I found no angle which works. These shots are from projecting from the right side: I tested with a sphere and found the bug to be harder to reproduce but it is still here: Quote Link to comment Share on other sites More sharing options...
New Member anton lazakov Posted June 16, 2020 Author New Member Report Share Posted June 16, 2020 Hey guys! thanks, everyone for the support! I prepared a picture to show what exactly goes wrong 1 I create an object in the sculpting room 2 The Cut tool works correctly, I can select the zones that I want to delete. 3 But when symmetry is turned on, I can no longer create zones for deletion, clicking on the left mouse button has no effect! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 16, 2020 Report Share Posted June 16, 2020 Symmetry AXIS type must be activated too Quote Link to comment Share on other sites More sharing options...
New Member anton lazakov Posted June 22, 2020 Author New Member Report Share Posted June 22, 2020 On 6/16/2020 at 11:21 PM, Carlosan said: Symmetry AXIS type must be activated too It doesn’t matter if the symmetry checkbox is active or not. The problem is that when symmetry is activated as an option and we can see its window in the viewport, the selection tools (Vertex Lasso, Stroke Lasso, Closed Spline) stop working Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 26, 2020 Report Share Posted June 26, 2020 Hi Check latest version please 4.9.51 - Fixed problems related to 3D-lasso + hide. Quote Link to comment Share on other sites More sharing options...
