stusutcliffe
Sculpt Layer with Paint Layer
Hi
Do you need a specific information ?
Can you duplicate the mesh and delete vertex information ?
I find it difficult to explain,
I dont like the sculpt layers because I keep sculpting on the wrong layers so when I delete a paint layer I no longer require I lose sculpt info I want to keep and vice versa.
If I switch off sculpt layers in the prefs they get reactivated when I open the scene that has them.
Basically I have a sculpt layer with vertex paint on Layer 1 what I think I want to do is flatten the sculpt layer and move the vertex paint to layer 2 then switch off sculpt layers in the prefs as I dont need them for now.
sorry if this is just gibberish, Im confusing my self now.   I want to extract the paint and sculpt from one layer and make it two layers, paint info one,sculpt info in the other.
You can always reduce the Sculpt DEPTH OPACITY to Zero on a layer, to basically hide/remove the Sculpt information. Or duplicate a layer that has both Sculpt and Vertex Paint > with only DEPTH Channel active hit the DELETE key. It will remove all depth channel information.
Ta for the help,
Im struggling to get my head around this. I think its because I have info in Layer 0  which I dont think you can get rid of. Think I am just going to have to live with it for this thing, then turn off sculpt layers for the next job.
I hope ther is an option to turn off Sculpt layers in the final release . I can see their use, but when you keep sculpting on the wrong layers by accident things start turning messy ,a bit like when you paint on the wrong layer but doubly so.
I just do simple stuff.
I found a solution to this I think.
I had to send of my model as an FBX so a client could work on it. So I brought it back in and now all is perfect ..sculpt is on Layer 0 paint is on Layer 1  , nice and simple . Before I had two sculpt layers 0 and 1 . So switching off all the beta tools for now.
Apologies if this makes no sense to anyone.
What would be the best way to bring an FBX back. I used the 'vertex paint and big reference'  I think it was called. I could not find an Import FBX button anywhere ....probably did not look very hard.
I was starting to like the new curves tools, but cutting off is still leaving faceted faces.
12 hours ago, stusutcliffe said:
Ta for the help,
Erase Brush in the Paint room (with just DEPTH channel enabled) will erase all sculpt layer info under your brush...or just hit the DELETE key to completely remove any Sculpt Layer information on a layer you may have accidentally sculpted on. I never found it to be a hassle in any way. You will get used to it, as it's very powerful and and flexible.
Ta for the info.
I think you need to be here .There are all sorts of permutations on this one.
Dont necessarily want to delete if all the best stuff is in that layer,and its got the paint I want. just merge down. But I think having a stuff in Layer 0 didnt help as you cant merge down to that layer...who knows.
Im sorted now, but thanks for the tips I will keep note.
I will practice more with this on my own stuff, not an actual job.
Thanks I will try it at some point.Is it diferent than using the option with right click mouse.
Im pulling my hair out over something else at the moment...but thats for another thread.
