3dmodels445
Polygons not showing up when creating loops and lines with stroke
Can anyone help?
I used the stroke tool to make loops around the arm and waist, then drew intersecting lines. When I press enter nothing shows up around the arm. When I draw strokes on a flat surface, like the stomach, the polygons show up.
A video and screenshots are below. I'm new to 3Dcoat, so my terminology probably is not perfect.
Hello
I am testing latest version 4.9.54 but cant replicate this issue. Sorry.
Try this tool on another mesh, like any default primitive from sculpt room.
Can you replicate the problem ?
Thank you for the fast response. I tried your idea, and used the male model in the sculpting room and added loop/polygons around the arm in the retopo room and it worked fine. It seems to be only not working on my mesh. I had no problem retopping the head and neck and ears, on my own personal mesh, so I don't know why only the arms are not working. I will keep trying...
Found a solution: The loops (orange lines) duplicates when drawn, in my case. I deleted each loop, and a one still remained. Then I pressed enter and the polygons work correctly. Thought I would add this in case any other newbs have this problem.
