[Solved] 3DCoat applink to blender
lemsway
HI Good day, i would like to ask an issue..about Blender to 3D coat Applink.. my workflow is. i usually create poly models in Shapr3D/Blender and others..then for PBR texture i run to 3D coat. but currently applink is giving me uncoordinated textures. please advice on what im missing or proper workflow. im attaching a screenshots. thanks and looking forward on this issue.
  • Applink Developer
the error you got in the video.
Can you check this location from your computer:
C:\Program Files\Blender Foundation\Blender 2.83\2.83\scripts\addons\io_coat3D\
is there data.json file in that folder?
Edited by haikalle
its not there..the whole IO_coat3D?...
  • Applink Developer
it's odd cause. if you are running blender.exe from that location and you don't see io_coat3D folder, then it should mean that you dont see 3d-coat applink addon in your blender. but it seams that you can see it even the folder is not there what makes this very odd :)
HI Haikalle, i did the other way around...i put in the io_coat3D in the blender folder..its no longer searching for the .Json. but the texture are still jumble up. :(
do you really recommend reinstalling a new Blender? im running the v2 83.0. thanks again
image.thumb.png.fc5086c8e60df2c5bcabd8cecdca5e7c.pngimage.thumb.png.52968247cf2a61f7ec4bed0465c9c585.png
4 minutes ago, haikalle said:
i dont understand :( regarding UV's
i tested my old files works before but now the texture is jumbled...
is your uv maps correct in range 0-1
Edited by lemsway
  • Carlosan changed the title to [Solved] 3DCoat applink to blender
