Member lemsway Posted August 16, 2020 Author Member Report Share Posted August 16, 2020 (edited) 17 hours ago, lemsway said: hi thanks again...now i got this message..which 1 i delete? thanks Edited August 16, 2020 by lemsway Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted August 16, 2020 Applink Developer Report Share Posted August 16, 2020 It seams that you have installed one applink version and it will conflict now with the one that comes with blender. Try to remove these addons and then replace zip file with /program files/blender fou.../.../addons/io_coat3d/ Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted August 16, 2020 Applink Developer Report Share Posted August 16, 2020 (edited) When I send these zip files its better to replace blenders default addon with them. Using 'install external addon' is not good option in this case. Edited August 16, 2020 by haikalle Quote Link to comment Share on other sites More sharing options...
Member lemsway Posted August 16, 2020 Author Member Report Share Posted August 16, 2020 18 hours ago, lemsway said: so i deleted the "IO" in the program files..did a test..but when i press the "getback" this error: Traceback (most recent call last): File "C:\Users\I9-9900K\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\io_coat3D\__init__.py", line 339, in invoke workflow1(ExportFolder) File "C:\Users\I9-9900K\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\io_coat3D\__init__.py", line 1356, in workflow1 blender_3DC_blender(texturelist) File "C:\Users\I9-9900K\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\io_coat3D\__init__.py", line 1130, in blender_3DC_blender tex.matlab(objekti,mat_list,texturelist, is_new) File "C:\Users\I9-9900K\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\io_coat3D\tex.py", line 697, in matlab readtexturefolder(objekti,mat_list,texturelist,is_new, udim_textures) File "C:\Users\I9-9900K\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\io_coat3D\tex.py", line 300, in readtexturefolder createnodes(index_mat, texcoat, create_group_node, objekti, ind, is_new, udim_textures) File "C:\Users\I9-9900K\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\io_coat3D\tex.py", line 441, in createnodes with open(json_address, encoding='utf-8') as data_file: FileNotFoundError: [Errno 2] No such file or directory: 'C:\\Program Files\\Blender Foundation\\Blender 2.83\\2.83\\scripts\\addons\\io_coat3D\\data.json' location: <unknown location>:-1 Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted August 16, 2020 Applink Developer Report Share Posted August 16, 2020 (edited) Its again that data.json error. Can you check if there is data.json file in C:\\Program Files\\Blender Foundation\\Blender 2.83\\2.83\\scripts\\addons\\io_coat3D\\data.js location Edited August 16, 2020 by haikalle Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted August 16, 2020 Applink Developer Report Share Posted August 16, 2020 Can you take a screenshot of files in that location? Quote Link to comment Share on other sites More sharing options...
Member lemsway Posted August 16, 2020 Author Member Report Share Posted August 16, 2020 18 hours ago, lemsway said: hi initially thers no "IO folder" i decided to make a copy of what you sent me..the "Getback button" works..but still the textures is jumbled up. the other screenshot is i believe the duplicate copy. Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted August 16, 2020 Applink Developer Report Share Posted August 16, 2020 Can you send picture of your uv maps? Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted August 16, 2020 Applink Developer Report Share Posted August 16, 2020 (edited) Could you send me a file to test out? You can send private message if you dont want to share it with every one. Edited August 16, 2020 by haikalle Quote Link to comment Share on other sites More sharing options...
Member lemsway Posted August 16, 2020 Author Member Report Share Posted August 16, 2020 19 hours ago, lemsway said: sent a test. thanks again Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted August 17, 2020 Reputable Contributor Report Share Posted August 17, 2020 On 8/15/2020 at 7:29 AM, lemsway said: ok, but how come my other models..which i worked using 3Dcoat applink before..is not working now? other than this ship..i sent other samples. thanks for being patience. When I have trouble getting the applink to work, the first thing I do is delete or move the BLENDER folder from MYDOCS/APPLINKS/3D-COAT/EXCHANGE. Then, export something from Blender to 3DCoat, to re-establish a connection. Quote Link to comment Share on other sites More sharing options...
Member lemsway Posted August 18, 2020 Author Member Report Share Posted August 18, 2020 16 hours ago, AbnRanger said: When I have trouble getting the applink to work, the first thing I do is delete or move the BLENDER folder from MYDOCS/APPLINKS/3D-COAT/EXCHANGE. Then, export something from Blender to 3DCoat, to re-establish a connection. thanks will try this. Quote Link to comment Share on other sites More sharing options...
Member lazyghoul Posted September 9, 2020 Member Report Share Posted September 9, 2020 Hello guys, Same issue here. After installing Blender 2.90 I had the same problem. I removed the addon that came with Blender with the one above. Also, tried what Carlosan suggested, no luck. ___________________________________ Traceback (most recent call last): File "C:\Program Files\Blender Foundation\Blender 2.90\2.90\scripts\addons\io_coat3D\__init__.py", line 579, in invoke bpy.ops.export_applink.pilgway_3d_coat() File "C:\Program Files\Blender Foundation\Blender 2.90\2.90\scripts\modules\bpy\ops.py", line 201, in __call__ ret = op_call(self.idname_py(), None, kw) RuntimeError: Error: Traceback (most recent call last): File "C:\Program Files\Blender Foundation\Blender 2.90\2.90\scripts\addons\io_coat3D\__init__.py", line 613, in execute coat3D.exchangedir = set_exchange_folder() File "C:\Program Files\Blender Foundation\Blender 2.90\2.90\scripts\addons\io_coat3D\__init__.py", line 137, in set_exchange_folder if(source != coat3D.exchangedir and coat3D.exchangedir != '' and coat3D.exchangedir.rfind('Exchange') >= 0): UnboundLocalError: local variable 'source' referenced before assignment location: C:\Program Files\Blender Foundation\Blender 2.90\2.90\scripts\modules\bpy\ops.py:201 location: <unknown location>:-1 _________________________________ Thank you for your support! Edit: If it helps, I also have Hops and Boxcutter installed, just like Lemsway has. Just saying.... Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted September 9, 2020 Applink Developer Report Share Posted September 9, 2020 @lazyghoul Please delete ../Documents/3DC2Blender/Exchange_folder.txt and try again. Now it should work. 1 1 Quote Link to comment Share on other sites More sharing options...
Member lazyghoul Posted September 9, 2020 Member Report Share Posted September 9, 2020 3 hours ago, haikalle said: @lazyghoul Please delete ../Documents/3DC2Blender/Exchange_folder.txt and try again. Now it should work. Now it works. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
Member liok Posted February 16, 2022 Member Report Share Posted February 16, 2022 Each time I get back to using the applink I forgot about this txt file prevent it to work, deleted it and now the applink finally works! thanks haikalle ! 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Britain Posted yesterday at 02:55 PM Advanced Member Report Share Posted yesterday at 02:55 PM (edited) The app appears to be broken in Blender 4.1. You can send but not get back. Works in Bender 3.6 Edited yesterday at 02:59 PM by Britain Add error Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted yesterday at 03:21 PM Report Share Posted yesterday at 03:21 PM 24 minutes ago, Britain said: The app appears to be broken in Blender 4.1 As far as I know, OneDrive is not compatible with the correct operation of 3DCOAT. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted yesterday at 07:02 PM Report Share Posted yesterday at 07:02 PM “3DCoat” is trying to create a user data folder (which contains user settings and assets) inside “C:\Users\USER_NAME\OneDrive\???????\3DCoat”. That is incorrect. It should create it inside “C:\Users\USER_NAME\Documents\3DCoat”. To workaround this problem: Start > start typing “Edit the system environment variables” > Environment Variables… > System variables > New… > Variable name: COAT_USER_PATH Variable value: C:\Users\USER_NAME\Documents\My3DCoatData (specify your user name inside) Source Quote Link to comment Share on other sites More sharing options...
Advanced Member Britain Posted 23 hours ago Advanced Member Report Share Posted 23 hours ago (edited) 4 hours ago, Carlosan said: “3DCoat” is trying to create a user data folder (which contains user settings and assets) inside “C:\Users\USER_NAME\OneDrive\???????\3DCoat”. That is incorrect. It should create it inside “C:\Users\USER_NAME\Documents\3DCoat”. To workaround this problem: Start > start typing “Edit the system environment variables” > Environment Variables… > System variables > New… > Variable name: COAT_USER_PATH Variable value: C:\Users\USER_NAME\Documents\My3DCoatData (specify your user name inside) Source I'm Lost here. I'm on Windows 11 and 3D coat version 4.9.72. There's no Start and no My3dcoatData. Where do I find the place to change the Path? Thanks! Edit: Blender 3.6.1 works fine. 3D coat is written in the same place. Yet I can pull back with that version its only Blender 4.1 that it fails. Edited 22 hours ago by Britain Quote Link to comment Share on other sites More sharing options...
Carlosan Posted 8 hours ago Report Share Posted 8 hours ago Sorry, this step is valid for version 2024+ Follow this walkthrough. Hope this help. Quote Link to comment Share on other sites More sharing options...
Advanced Member Britain Posted 50 minutes ago Advanced Member Report Share Posted 50 minutes ago 7 hours ago, Carlosan said: Sorry, this step is valid for version 2024+ Follow this walkthrough. Hope this help. Thanks Carlos but the issue I feel is with the Blender version 4+. Using the Blender 3+ everything works fine. Has soon as you go to version Blender 4 it fails. I did the step above and nothing. LOL that onedrive is dangerous and intrusive. 1 Quote Link to comment Share on other sites More sharing options...
