[Solved] How to create muscles on new layer ?
So this seems more difficult than it should be.  I've imported a skeleton, in Voxel Sculpting mode, and I want to use the muscle tool to create muscles on it.  However, I also want to import the skin mesh, to ensure that the muscles are between the skeleton and the skin.  I spent a lot of time trying to import this, after loading the skeleton.  When I was just importing the skeleton at the default size, there weren't enough voxels to get detail in the ribs and such.  So I auto-scaled it up.  But then, I couldn't get my skin mesh to import at the right scale.  The only way I could find to get around this was to check the "import without voxelization" option.  Then, I'm able to get both of my models imported at the correct scale.  In the Sculpt Tree, I create a new Layer.  I now pick the muscle tool, under objects, and draw from one point of the skeleton to another.  However, it doesn't create it on the select layer.  It creates it on the skeleton layer, or on the skin layer.  I'm not sure what turning the minus to a plus, on the left side of the layer does, as there's no pop-up info, but it doesn't seem to help.  Does anybody know how to do this so that the muscle is it's own object, and not added to existing ones.  I tried turning on ghost mode for the existing objects, so I don't accidentally pick them, but then I can no longer click on the skeleton to start a muscle on it correctly.  Anybody know what I'm doing wrong?  I couldn't find much of any videos or links on this problem when I looked.  :-/
  • Carlosan changed the title to [Solved] How to create muscles on new layer ?
