Member tritochke Posted September 7, 2020 Member Report Share Posted September 7, 2020 I'm currently using latest beta build .59 and few days ago I've noticed issues with smart material preview not being updated in thumbnail which renders all my newly created materials to look transparent, and of course you can imagine this leaves me clueless as to which material I'm actually using. I've tried to reinstall coat in order to try and fix this issue and for a moment I thought I succeeded, then I realised that issue is still here still, every time I make new material. Ok, so, this is one problem which I don't know how to fix, manually refreshing materials DO NOT work. My second issue i'm experiencing at the moment is even bigger one and it's also related to materials and how they are being perceived through the viewport '' preview '' window and the actual application onto the layer itself. i'll add image below to show you exactly what I mean. basically, probl is that when I view material in preview window it looks OK - BUT when I apply it to the layer via paint brush or fill bucket material is not correct. Quote Link to comment Share on other sites More sharing options...
New Member kristinatoxicpanda Posted September 9, 2020 New Member Report Share Posted September 9, 2020 I have the same issue. When I create smart material, preview is not showing- it looks like the material is transparent. This is almost permanently present , but sometimes 3d coat shows material, and if i restart it than again the thumbnail is transparent. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 9, 2020 Report Share Posted September 9, 2020 Hi Test GL version: same issue ? Thx Quote Link to comment Share on other sites More sharing options...
Member tritochke Posted September 9, 2020 Author Member Report Share Posted September 9, 2020 Hi Carlosan, I'm only using GL version, never used anything else Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 10, 2020 Report Share Posted September 10, 2020 Are 3 channels active ? I cant replicate, sorry Please share the material to take a look Thx Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted September 11, 2020 Reputable Contributor Report Share Posted September 11, 2020 All my tips and questions or only to effect a solution. The viewport problem: The preview window renders at 8k resolution I believe but the quality of the applied the material depends upon your texture resolution. In the smart material editor have you unlocked depth. This will cause the depth to depend upon the pen radius and depth setting in the top menu. Question. Have you moved the location of the images associated with your Smart Materials on your hard drive. I also would be interested in looking at the shaders through the extension pack that Carlosan suggested. When creating new smart materials you can move them to a new folder you create. That is what I do. Quote Link to comment Share on other sites More sharing options...
Member tritochke Posted September 12, 2020 Author Member Report Share Posted September 12, 2020 On 9/10/2020 at 4:50 PM, Carlosan said: Are 3 channels active ? I cant replicate, sorry Please share the material to take a look Thx Yes, all 3 channels are indeed active, I'll send you my materials asap. Quote Link to comment Share on other sites More sharing options...
Member tritochke Posted September 12, 2020 Author Member Report Share Posted September 12, 2020 23 hours ago, digman said: All my tips and questions or only to effect a solution. The viewport problem: The preview window renders at 8k resolution I believe but the quality of the applied the material depends upon your texture resolution. In the smart material editor have you unlocked depth. This will cause the depth to depend upon the pen radius and depth setting in the top menu. Question. Have you moved the location of the images associated with your Smart Materials on your hard drive. I also would be interested in looking at the shaders through the extension pack that Carlosan suggested. When creating new smart materials you can move them to a new folder you create. That is what I do. Interesting though, however, my material is simply a small 100x100 px white layer, I'm using it only as a base that I then colourise in Coat. So, basically, it's almost resolution independent you could say. As far as resolution of my map is concerned it's 4K so it's should show all the necessary details within preview window, because my NM is showing them as well, so they are present in the map. As far as depth goes, i've never touched it, it's basically on default. being '' locked '', and since I haven't used any depth details in my material and I'm only painting here with solid colours ( all the depth details you see here are from my NM, not material ) I highly doubt that it's the root of this problem. I appreciate your take on it, thank you and yes, i'll def share materials, maybe you'll see better what i'm doing wrong here, and of course if perhaps this is indeed a bug. thank u ! N. p.s. just give me some time to organise this share folder, i'll try and share it asap. cheers Quote Link to comment Share on other sites More sharing options...
Member tritochke Posted September 13, 2020 Author Member Report Share Posted September 13, 2020 hi all, little update on the situation regarding '' smart materials '' thumbnail preview, I'm doing my best to try and replicate this problem from ground up in order to see if there is some sort of pattern to it, but I've not had any luck with that, even two days ago when I was finishing textures on one simple character issue was present each time I created new material so I have to conclude this happens on random. If I may propose this thread stays open till I see this issue again and I'll share my materials immediately when that happens. I've also had an idea about potential source of this problem and it concerns environment map, lately i've started using new Hdri map and I haven't ''normalised it '' inside 3DCoat, so, roughly around that time this issue with material preview started to appear, soo, perhaps this is somehow related to EnvMap , just a guess ?!? As far as materials not being correctly applied I'm sorry I cannot dig out that particular material, I believe I simply deleted it believing that something is wrong with it and opt-ed out for different material/approach for that texture all together. Also, If I see this issue again I'll share this image and material immediately on this thread. thank you for reaching out and helping me, I appreciate it. N. 1 Quote Link to comment Share on other sites More sharing options...
