Member alexios Posted September 8, 2020 Member Report Share Posted September 8, 2020 Hi, i'm trying to play with the alpha(transparency). As i understood, in order to use alpha (for all layers) one can just remove with the Eraser the needed. The issue with this is that i can t remove with hard edges, the Remove brush somehow creates antialiasing(gradient) which i want to avoid. Also another issue is that sometimes even if i m using the erase tool some parts are reappearing even if it should have been removed already. Is something i m missing? Thanks! alpha.zip Quote Link to comment Share on other sites More sharing options...
Advanced Member sprayer Posted September 8, 2020 Advanced Member Report Share Posted September 8, 2020 (edited) For me the same every "playing" in 3d coat gives some errors and bugs, i hope developer can "play" and fix all bugs someday otherwise this tools works only for old users what knowing that they are doing and how it should work to find workaround. @Andrew Shpagin should do something with ton of bugs Edited September 8, 2020 by sprayer Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 8, 2020 Report Share Posted September 8, 2020 Confirmed and reported. Thx for point it up Quote Link to comment Share on other sites More sharing options...
