[Solved] weird import scale issue
pickers
Hi, i have a weird scale issue with a particular file. If i tried with new import in a new project either in 4.8.40 or 4.9.65, both will not have issues with scale.
However, if i tried new import to an existing project, the scaling is off when i export to external program as seen in the image.
work process :
1) import obj(female char) to current project.
2) use a box to cut off the shape of the obj (Female Char).
3) export box as retopo obj
4) import box to external program to match the obj. Failed as shown in the image!
So..... how to reset scale in a current project? or export scale correctly.
Edited by pickers
  • Carlosan changed the title to [Solved] weird import scale issue
