geo_n 59 Report post Posted November 15, 2020 Is there a way to exclude some uv islands from the packing process in the uv room? Its one reason I don't pack my uvs in 3dcoat because I don't know if its possible to specifically lock some uv islands and only affect the other uv islands. Share this post Link to post Share on other sites
pickers 24 Report post Posted November 16, 2020 If you want to pack some of the islands in certain location in the UV map, With Mark seam selected, - Select the islands in UV map - Commands>> UV settings try with different the Min MAX U and Min Max V settings. - you can move the islands out of the default square first when managing the islands. Is that what you are asking? Share this post Link to post Share on other sites
tokikake 60 Report post Posted November 16, 2020 (edited) I could not find "pack" command as selectable. (or only effect visible part only) Though there are many UV command, which work for Selected only, but Pack command seems not work so. (it need to change FULL isnalds or we need to change UV set for the islands, but it can not use as one UV sets .(it just pack separately for current UV units) , So I suppose there is no option which geo_n expect.. (but of course we can manually adjust or scale for selected islands manually, or can use other many uv command (group as selected) I suppose he talk about kind of pin UV tool. (or simply try pack only for selected island ) Edited November 16, 2020 by tokikake Share this post Link to post Share on other sites
geo_n 59 Report post Posted November 16, 2020 @pickers not exactly. I did try to do what you suggested. @tokikake yes uv island pinning. I want to pack only other uv islands and some islands should not get affected by packing process. Other 3d apps have it. Ex in lw. I want the lower left uv island to stay in place and pack the others. Share this post Link to post Share on other sites
pickers 24 Report post Posted November 16, 2020 i havent seen an island pinning function before. Maybe a good time to put up a feature request? : -) Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted November 19, 2020 https://youtu.be/I7EO90yips8?t=158 Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted November 19, 2020 http://3dcoat.com/mantis/view.php?id=341 UV Tool: Pin Selected/Unselected feel free to add +1 Share this post Link to post Share on other sites
geo_n 59 Report post Posted November 27, 2020 Access denied in Mantis. No anonymous login? 1 Share this post Link to post Share on other sites
geo_n 59 Report post Posted November 27, 2020 On 11/19/2020 at 7:35 PM, Carlosan said: https://youtu.be/I7EO90yips8?t=158 That looks more complicated that it should be. Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted November 27, 2020 5 hours ago, geo_n said: Access denied in Mantis. No anonymous login? No to avoid spam avalanche To create new user send me PM with email, name, psswrd you like to use for login Share this post Link to post Share on other sites
